Turbo Upgrade Sneak Peek
dc2turbo
usa
civic,teg
He doesn't it's just the with the CVT you have the ability to let it sit at a constant rpm while accelerating. So technically he does sweep through that once but doesn't see it on every shift like a manual. I haven't driven this CVT but I think D simulates an AT but S mode just holds the rpms steady while accelerating...
d and s both goes from the range 4000-6000
L holds it at redline
dallasjhawk
Royse City, TX
I dont like how S feels over 70 mph. I usually put it back to D once Im mid 70s if Im on a full throttle run to 100
Quicksipper
FW Tx
16' EX-T, 05' LX
I'm curious as to where the peak horsepower would land. I know from having my Honda Fit CVT tuned, I was not able to have the CVT moved around to a different rpm, to take advantage of a new horsepower peak. I had custom grounded Deltacams made and installed so this is why I was interested in this. This is why I am asking about where the new peak horsepower will be with this turbo upgrade (if there will be a new peak hp). Won't know until it's dyno'd. But if it is not where the CVT operates at now, won't be justifiable to upgrade to a new turbo.
you speak the truth, this is how I felt with my tune
  • Like
Reactions: Myx
Myx
Delaware
How do you skip 3500-5000?
AsianGuy98, maddmatt doesn't know what I'm talking about. I meant exactly what I said but I am using the term 'skip' loosely. Let me explain it to you in PM. I don't want to derail the thread by explaining it.
I was just thinking:
Less
Honda Civic 10th gen Turbo Upgrade Sneak Peek 359269F2-021C-4E7B-8168-28B097B8B518
More
Honda Civic 10th gen Turbo Upgrade Sneak Peek 0FC888DF-1930-4F89-A5F7-5B42C02B9B66
IronFusion
Fred
Philadelphia, PA
2017 Civic Coupe EX-L
Less
More
So another patent answer that the only way forward is with an entirely different car than what might be a majority of folks have (CVT)? Points for creativity on the delivery.
I bet the power and torque curves might differ, to accommodate the lackluster CVT in the Civic, but in the end the limiting factor is the engine internals regardless. And that would show on the dyno. Cool, if that's what you care about. The difference in track times between the two transmissions with a turbo upgrade would be at high enough of an rpm and speed that the differentiator on everything under a CTR will be the Si's LSD and tires across the board. If the CVT (of which the potential disappoints me) can be accommodated, than there will either be no difference, or CVT cars will best IRL Conditions.
I pray Honda, or anyone else, delivers a mod-friendly car like the Civic but with an available CVT that does the tech proud. Then, the argument of CVT Proponents won't be based 'on paper' anymore, the jury won't be out, and we can live in a world where folks are entitled to their opinion but not their own facts.
To clarify my post, I only meant less CVT discussion and more compressor wheel discussion in this thread, as per the OP. :thumbsup:
IronFusion
Fred
Philadelphia, PA
Apologies for the rant. Look at enough replies in various threads, and you begin to assume it's all the same. I thought the thread was about an entire bolt-on replacement. Anyone can go to the different veined Si wheel already- what more can be gained from a modified compressor wheel?
Myx
Delaware
Topend! Since that's where the stock turbo's compressor wheel's horsepower falls off. The small turbo should be perfect for most people since very few will spend a majority of the time taking advantage of that topend power. That torque is pretty badass though. :headbang: It's a compromise. Very interesting to see where this goes either way.
dallasjhawk
Royse City, TX
The small compressor wheel can make power really fast but only so much power because of its size. You get a bigger compressor and it might take a split second longer to boost, but you can make boost longer and the larger compressor makes more power but slightly higher up in the rpm band as well. Remember, torque gets you moving, hp keeps you moving. These cars make plenty of torque so getting a slightly larger compressor would get you more horsepower and be less likely to peter out before you get close to redline.
simon_lefisch
2020 Civic Si Coupe
Stumbled across this thread, as I was just wondering if the stock turbo could be upgraded. Would love to hear an update on this. Looking forward to the end result.
maddmatt02
marysville, wa
2017 civic ex-t 2016 crv lx 2001 accord ex 1997 integra gs
Based on this post now I'm assuming you were talking about your "myxal 2 step" trick.
davemarco
Madmatt, have you heard anything from Vit on the subject of the turbo upgrade?
maddmatt02
marysville, wa
I haven't heard anything that I'd share other than it wasn't ready...
Had I heard anything else he hasn't made public himself I wouldn't share it anyways, that's a good way to get kicked out of the inner circle...
Now I'm not saying I *am* in the inner circle either... lol. I'm not :(.
