Turbo Emblem
Stevo
Stevo
Lake Worth
Honda Civic Hatchback EXL Navi 2017
I am leaning towards placing it exactly as you have, I think it looks more 'factory' since that is where the Touring badge is. Did you just use painters tape to line it up with the Civic badge?
Yes, I did use painters tape
Yosemite Sam
Honda was my first car brand and probably my last!
Indiana
2017 Civic Hatchback EX
Last question, Did you line it up with the top of the Civic badge? or did you try to center the Turbo badge? I am not sure if that makes sense.
Stevo
Stevo
Lake Worth
Well the turbo badge is shorter and narrower than the Civic Emblem so o could not line them up exactly. But I wanted it to be around the same general place as the Civic lettering. I pretty much used the painters tape to make sure it was level and in the correct spot.
khnovak10
Cleveland, OH
2016 Honda Civic EX-T
Put it on this side, only issue is that the badge doesn't really bend well considering the trunk is not completely flat, and some of the white tape stuff behind it is visible, may end up getting some of the tape and re apply myself
Yosemite Sam
Indiana
Put it on this side, only issue is that the badge doesn't really bend well considering the trunk is not completely flat, and some of the white tape stuff behind it is visible, may end up getting some or elf the tape and re apply myself
Looks good! I see you are in Ohio. I am in Indiana so I am waiting until it warms up before I put mine on, I assume (maybe wrongly) that it will affix and bend a bit easier when it is not so cold!
Lunar
NorCal
2016 Civic Touring Sedan
The Acura turbo emblem looks decent, but I'm not sure where I would put it since I have the touring decal
Yosemite Sam
Indiana
I saw another person on here with a touring and I think they put the Turbo badge under the Touring emblem, it looked pretty good. There are several threads on it so I would check some more pictures if I were you!
misspriss40
Happy..our Not! HONDA
Omaha,Neb
2016 Honda Civic coupe
Id get mothers brand black..
Also im gonna go ahead and say its problably residue from some sort of wax/polish meant to be used on painted surfaces..
I took too dealer and they are replacing free
