Turbo Blanket / Downpipe Blanket...issues
SpinRush
Big Will
Japan
FK8 ( Waiting )
Japan Honda FK8 Civic Type R
Goal: Thermal Management build
Product: GRP Turbo Blanket and Downpipe Blanket.
Snag #1: Downpipe Blanket won’t fit around OEM Downpipe. We thought we could live without it cause it doesn’t have it anyway.
Snag #2: Turbo Blanket fits perfectly...but....OEM Heat Shield can’t be put back on. The Turbo Blanket blocks the top and bottom holes where it bolts down. The downpipe bolt on point is no problem.
The OEM Heat Shield is not really that big. However, we know it serves a major function, to keep that heat off away from sensors. I’m at crossroads. Here are a couple of pics that illustrate the problem.
I would really love some advice right now. It’s really hot under the bonnet. That downpipe is an oven.
whymi
michael
cali
93 si, 17 type r
I believe the downpipe blanket is for THEIR downpipe, not OEM catted. As for the heat shield with the blanket, I was able to put 2 of the 3 bolts back on. It seems to fit securely with no rattles that I have noticed.
Simmons572
Regi
WV
96 Civic LX
I am fairly certain the downpipe blanket is supposed to be utilized for an aftermarket high-flow cat or catless downpipe. Something like the RV6 or the PRL offerings.
Can't speak for the turbo blanket snag though.
toddrhodes
Todd
Indiana
'18 CTR #16979, '18 Odyssey
I had to slightly roll the edge of the turbo blanket under itself to expose one of the holes for mounting the factory heat shield. I opted to keep the heat shield because even with a ceramic coated DP and turbo blanket, IAT temps were noticeably lower after reinstalling the heat shield than prior, when I was running without it for a couple of days.
SpinRush
SpinRush
Big Will
Japan
FK8 ( Waiting )
Thank you so much for responding so quickly. I contacted Graham Rahal Performance. They had experienced this problem with another Type R Owner. I went to the post office tonight to send it back to them.
I believe I will follow your method. Which 2 bolts were you able to get back in? Also, I will try to roll the edges just a bit. If can get at least 2 bolts in that will be a victory in my book. Then I can move on to better things.
I’m really not trying to “BOOST” this car. I’ve heard so much about heat sink issues so I decided to go with a thermal management build. I’m still waiting for my Seibon Front Grill which should give me a lot more air flow into that area.
Other snags I experienced were with the HKS SQV4 Blow off valve. It won’t fit with an Eventuri CAI. So I went with the Eventuri and put the BOV back in the box. The BOV piping was a problem. It had this stem attachment for the hose that would allow the CAI box to sit flat. Oh well.
Everything else seems to be going well. The new HKS exhaust is so good. The HKS Intercooler fit perfectly. 2 out of 3 is not bad.
alejandroads123
Daniel
Civic type R
That downpipe blanket is designed exclusive for the GRP high flow cated downpipe. The best solution buy the GRP downpipe, and you will get improvement over stock downpipe , quicker turbo spools up and in the future with a tuning solution better performance.
SpinRush
SpinRush
Big Will
Japan
FK8 ( Waiting )
Japan has to deal with car inspections and it may be a complication. More research is required on my end. What works overseas does not always pass inspection here in Japan. Thank you though for your advice.
metal_driver
Ottawa
2004 TSX (Euro-R mods), 2009 Acura TSX, 2008 MDX, 2011 Shelby GT500, 2018 Type R, 2020 MDX A-Spec
I have seen others mention that wrapping a catted factory dowpipe is not a good idea anyway..
SpinRush
SpinRush
Big Will
Japan
FK8 ( Waiting )
I concur. With that said, until HKS Japan produces a downpipe specifically for the Japan version of the FK8 ( Pass Certification ) I’ll leave it alone.
I’ve got a plan that I discussed with my mechanic. We are definitely going to get those IAT temps down.
SpinRush
SpinRush
Big Will
Japan
FK8 ( Waiting )
The bolt just behind the radiator is the one i left off
I’m going to document the process in this thread over the next couple days.
Quick update: After doing a lot of research and getting some feedback we are moving forward again. Last night, my mechanic and I talked about possible solutions before I even got around to speaking with you guys. The turbo blanket looks so good and we really didn’t want to cover it up completely. We discussed cutting the heat shield slightly and painting it with heat resistant paint. Here’s a pic of what we did to heat shield.
We are going to get that heat shield back in.
elmerzasty
Poland
FK8
FWIW I just made a small hole in the turbo blanket for the third heatshield hole and mounted the heatshield with 3 bolts over the blanket.
alejandroads123
Daniel
Civic type R
You right, I haven think about it... The regulation there are restrictive like other states like California. To be honest whit you I don't think any high flow cated downpipe pass. The OEM catalytic converter is doble ceramic unit.
SpinRush
SpinRush
Big Will
Japan
FK8 ( Waiting )
Quick update since I started talking about this project. This is where we are at so far.
We got the heat shield painted ( 3 coats top and bottom ). I think it looks better after cutting the heat shield. We got the Eventuri CAI installed again. Right now, the car is being polished and I’ll pick it up later today. I’ll take some pictures later.
The biggest problem was trying to fit the HKS SQ4 Blow Off Valve with the Eventuri CAI. It’s always after the fact that you find the solution. Evasive Motor Sports actually has an adaptor kit with a shorter rubber hose mounting. Plus, it comes with a separate mount so I can move the BOV further back. So that means, in a few weeks or so, I’ll have to take the airbox out again and reinstall the intercooler piping. What a pain!
We are having so much fun, aren’t we? Hopefully after that, we can get to tuning with Hondata. I want to get the turbo to spool up a little bit sooner. We’ll see. It’s not a high priority item.
Again, thanks for taking the time to post. Appreciate all the help.
IHadToRun
Manuel
2019 FK8
id love to see full engine bay photos when you get the chance!
