jack.
- Jack
- Sep 23, 2020
- 15
- 425
- 268
- Peoria, IL
- 2018 Honda Civic Si Coupe (sold)
- Vehicle Showcase
Thanks for the clarification, that makes a lot of sense. If I understand this correctly, you can have 5 different tunes on the ktuner device, but only one is active at a time. What you can actually switch between is the 3 different “sub-tunes” or stages within that tune. You need to flash the ecu again to change which of the 5 tunes you use, but you don’t need to do that for the stages. Again, thanks for the clarification.Theoretically, if I bought the TSP tune, I'd be able to load it in say, slot 4, keep Phearable in 5, then do some base KTuner maps on slots 1-3. I only own the Phearable tune and the tunes that came with the KTuner. I've been thinking about buying the TSP just for shits and giggles, just to compare the two, however
this exactly. You'd have to flash different tunes loaded in the different slots, and you can only have one active. Better wording than what I had. lol. To put that in real world terms, if I wanted to use the 21psi tune with quick enables, I'd have to park it, flash it to the ECU, then run with it, and I would not be able to use any of the Phearable stuff, since the only tune flashed to the ECU at that point would be the 21PSI tune with quick enables.
