ı tried nearly all the basetunes and all the quick adjustmens except disable dampening but i have very few options because my ecu has initial support also ı have a strange boost problem. İ cant hit max boost before 5500 rpm and boost is not stable.Just want to know what tunes are you using for the 1.5t cvt and what adjustments you've made to tour tunes.
Thank you for the info ,i will definitely tweek the tu e ,just didn't want to set anything too high and fuck my car up lolThose are all safe. The one you don't want to touch is disabling boost ramp.
And clearly NEVER brake launch your car.
I also find if you go too aggressive with early spool and part throttle turbo responsiveness, the car will feel amazing off the line but will fizzle out a bit on the top end.
Best thing to do is just experiment til you find the combo that works best for YOU.
But gotta shave off those few tenths of a second on the 1/4 mileThose are all safe. The one you don't want to touch is disabling boost ramp.
