Tuning 1.5t cvt with ktuner
Klap1986
Kyle
Usa
civic
Just want to know what tunes are you using for the 1.5t cvt and what adjustments you've made to tour tunes.
kadireren
kadir
Turkey
Civic 1.5T Hatchback Sport + CVT (182ps)
ı tried nearly all the basetunes and all the quick adjustmens except disable dampening but i have very few options because my ecu has initial support also ı have a strange boost problem. İ cant hit max boost before 5500 rpm and boost is not stable.
Klap1986
Klap1986
Kyle
Usa
civic
I haven't had any issues so far with the map stage 2 tune
BoxsterSteve
still plays with cars...
Steve
Baden, ON
2000 Porsche Boxster S, 2018 Civic Touring sedan
CVT 21 psi stage 2 base tune on my 2018 Touring sedan with no other tweaks.
Very dramatic power increase, quite happy with it as it is.
Klap1986
Klap1986
Kyle
Usa
civic
Im curious about the quick adjustments with ktuner like throttle response 1 and two and the other quick adjustments with ktuner and what the car can handle without fucking the car up lol
Those are all safe. The one you don't want to touch is disabling boost ramp.
And clearly NEVER brake launch your car.
I also find if you go too aggressive with early spool and part throttle turbo responsiveness, the car will feel amazing off the line but will fizzle out a bit on the top end.
Best thing to do is just experiment til you find the combo that works best for YOU.
Klap1986
Klap1986
Kyle
Usa
civic
Thank you for the info ,i will definitely tweek the tu e ,just didn't want to set anything too high and fuck my car up lol
xjoshuax89
Josh
Maryland
But gotta shave off those few tenths of a second on the 1/4 mile :(
Klap1986
Klap1986
Kyle
Usa
civic
I just want sportier driving around town and better throttle responce from stop. I've read alot on this forum before buying the ktuner 1.2 and im glad i did ,now in just trying to find the right adjustments that fit me and the car without doing any damage to the cvt or the 1.5t.
Here's one of the setups I liked when I was on the Starter tunes. Map 1 is super aggressive. Map 2 is somewhat aggressive and Map 3 is the everyday commuter type tune. I had early spool enabled.
Klap1986
Klap1986
Kyle
Usa
civic
Thank you ,that's what i was looking for but how do i change from map 1 , 2 ,and 3 on the fly like i was hearing about?
If KTuner offers OTF support for your ECU:
With cruise control off....
Hold cancel for 2-3 seconds.
Use the cc (+, -) buttons to switch maps.
What will happen is the tach needle will go to 1000, 2000 and 3000 rpm and represents Maps 1, 2, 3.
Holding cancel again for 2-3 seconds choses a map. If you did it right the tach rpms will revert back to showing engine speed.
If your ECU doesn't have OTF map switching support, you just will have the first map (listed as Tune 1 in the software).
