TunerView Lite Now Available For The Head Unit
Andre80
white civic
Europe
Civic X 1.5 sport +
I checked the data in real time with autel ap200. I noticed that it reads the oil temperature, the oil level, and the torque plates, is it possible to have them for n tunerview?
Mestiso863
Ace
Vallejo, Ca.
2019 Honda Civic Sport Sedan Rallye Red
It gives me great pleasure to announce the public release of our TunerView Lite Android app for the head unit absolutely free. Lite because it does not include some functionality, like the overlay video and google map location tracking.
This powerful app connects to any KTunerFlash V1.2 or V2 device via bluetooth and offers up 9 beautiful layouts to view real-time information. These layouts are fully programmable from the items shown on the screen to the colors of text and more. Match your style easily through the menu system.
To Root The Head Unit:
Current steps to root for 16-17 models are here:
https://forum.xda-developers.com/android/general/guide-how-to-enter-developer-mode-2017-t3621582
2018 owners. There is a new method of rooting via the web browser. Honda Hack is what you want to use for rooting.
What you need to do after rooting:
  • Put the app on a USB stick and plug it into the vehicle's USB port.
  • Use Honda Installer to install the app from the USB stick.
  • Download the latest KTuner software update, 1.0.8.2, available now from the KTuner website downloads page. Install, launch KTuner, and plug your device in to update it to the latest firmware. http://www.KTuner.com/downloads
16-17 Models
  • For V1.2, once connected to KTuner after updating you can find the V1.2 Special Command Menu under the Tuning menu in the software. Find BT PIN Disable and choose it. This puts the unit into a mode that's discoverable by the head unit and requires no pin to pair.
  • For V2 users after you've updated you'll find BT PIN as an option on the main menu of the V2 device. Choose disable from the BT PIN menu to program it into the required mode.
  • Pair from your head unit.
  • Launch the TunerView Lite App.
2018 Models
  • You'll need to install version 1.0.8.2 of the KTuner software, or later. Grab the current version from www.KTuner.com/downloads
  • After installing it will ask to update your firmware once you plug the KTuner unit in. Make sure you have good power and do so.
  • For V1.2 once updated and connected again you'll need to select Enable BT PIN Advanced In the Special V1.2 Commands under Tools menu.
  • For V2 under BT PIN on the main menu choose Enable Adv.
  • After it completes reset power to the unit by unplugging both USB and OBD sides.
  • Plug it back into the OBD side only and key on to accessory mode or start the vehicle.
  • On your head unit run the TunerView Lite app, go to connect in the TunerView menu, and choose search to show BT devices. Choose the KTuner unit on the right. If all is well it should connect!
ALL MODELS
Follow our guides to use the menu and connect.
The guides which come included with the standard TunerView app will also be added to the KTuner Online Help when it is refreshed.
For V1.2 users you can flash tunes stored on your V1.2 directly from the head unit! Also activate On Board Logging.
We look forward to your feedback. Enjoy!
Is this available for 2019 models?
Andre80
white civic
Europe
Civic X 1.5 sport +
[QUOTE = "Andre80, post: 717971, membro: 18009"] I checked the data in real time with autel ap200. I noticed that it reads the oil temperature, the oil level, and the torque plates, is it possible to have them for n tunerview? [/ CITAZIONE]
i request
Inertiaman70
Minneapolis
13 Mazda 3 i Touring Hatchback
So, I bought a ktuner recently, been running for a couple of weeks with no issues. Went to put tunerview lite on my head unit yesterday and everything has gone haywire. My electrical system seems totally jacked. I was getting a lot of warning lights and it wouldn't start. Now the power barely comes on for a short period then everything goes dim and turns off. I managed to uninstall tunerview lite, but still having issues. I disconnected the battery to reset the computer but that didn't help.
HELP!
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
HELP!
TunerView can't cause any of that and neither can KTuner. Sounds like your battery.
Inertiaman70
Minneapolis
Thanks for the prompt response! It sure seemed odd that it would cause any electrical issues but it happened while I was working on that so I made an (incorrect) assumption. It's possible I left a dome light or something on the night before so tbe battery was already low. Then I spent time on accessory mode while I installed the software, etc. and then it went south from there. I will get the battery charged and hopefully that will resolve the issue.
freezingmoon
Jon
Brooklyn
2018 civic si coupe
My tunerview lite stopped working in my car today, 2018 civic si... has been working fine all year with it only occasionally disconnecting randomly but starting back up without a hitch when I’d either restart the car or push in the side view camera button, but today when i started my car to go work tunerview started in a frozen state and when i went to reset it by pushing in the side view camera button it just shut off and went back to the main car play screen, now when I try to start up tuner view it just quits and goes back to the main CarPlay screen and it won’t start again...
Anyone else have to deal with this at all?!?
Linszter
TunerView Developer
Peter
Hungary
2003 Accord K24, 2005 Civic K20 VSA
Update it to the latest version.
freezingmoon
Jon
Brooklyn
2018 civic si coupe
How do you update it?!? Sorry to ask but it’s been a year since I installed tuner view and I recall it being quite a process to install and I have no idea how to update it...
Thanks!
Linszter
TunerView Developer
Peter
Hungary
freezingmoon
Jon
Brooklyn
2018 civic si coupe
So just to be clear, I just have to download the new version of tuner view onto a usb stick and put it onto the USB port in my car and upload it to the car again?!? Do i have to do anything with the Ktuner software as well or is that all i need to do?!? Sorry for being a little out of touch! I appreciate the help!
Linszter
TunerView Developer
Peter
Hungary
Yes just install it over. No need to do anything with KTuner software if it's worked before.
