Si Tsp stage 1 not making much power
Ahxgen9320
Adrian
Houston
Civic Si
Had any had a dyno reading on Tsp stage 1 not making enough power???
Honda Civic 10th gen Tsp stage 1 not making much power 48F18A04-2AE8-4896-9C13-BB37AC2268D2
kytos
Marcos
Madrid - Spain
CIVIC SPORT 1.5t 2017 EUDM
Make sure Advanced VSA is not enabled (MAIN on). Can you explain the 2 lines? 1 stock and 1 tuned? A 50+hp gain is really good.
I'm with kytos. 57 whp is a really nice gain over stock.
I know TSP got something like 219 whp on their dyno but remember dynos and dyno readings vary for many reasons. And I'm pretty sure your Dynojet results are conservative compared to something like a Dynapack.
I'm assuming this is a non-Si.
kytos
Marcos
Madrid - Spain
His profile says it's an SI. Numbers are low but it depends on the dyno... I had a friend making 180 instead of 240 just because aVSA was enabled (on the dyno confusing the ECU), so that's why I'm asking. If the 2 lines are stock vs tuned the gains seems pretty solid.
Pur3MotioN770
Texas
2017 Civic Hatchback Sport 6MT
It's labeled as Si
Myx
Delaware
If the blue line is the stock tune, that'd be a 57whp gain, TSP advertises a 55whp gain, so that'd actually be spot on the money, just a low reading dyno.
What this man said right here. You made 57whp more than you previously did. That's great.
Ahxgen9320
Ahxgen9320
Adrian
Houston
Civic Si
Is that the vsa on off parking brake thing??
Ahxgen9320
Ahxgen9320
Adrian
Houston
Civic Si
@gtman its an Si.
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
Advanced VSA is a ktuner feature that pulls timing and throttle like factory VSA, but, less aggressively.
You might not have it enabled if you weren't familiar with it being available. It will definitely throw off dyno pulls
Disable it and rev hang disable on the fly by turning on cruise control
Ahxgen9320
Ahxgen9320
Adrian
Houston
Civic Si
Dang ok. Thanks for the info!!
