charleswrivers
- Charles
- Nov 3, 2017
- 43
- 3,736
- 4,468
- Kingsland, GA
- '14 Odyssey, '94 300zx, 2001 F-150
- Vehicle Showcase
Driving it hard... allowing the revs to approach the upper RPM range then shifting and staying WOT isn't what's hard on the clutch. Sitting at highway speeds and giving the car enough throttle (and it doesn't take much) to reach high levels of boost is what's bad. Think about where your torque peak is... and that you're essentially demanding nearly peak torque on a high (small) gear. That counter torque is not going to do any favors to any clutch... but one that doesn't have outstanding holding power is just going to give up. I'm at about 15000 miles... probably half of them now on TSP Stage 1... and I think 10 months to the day (pretty sure I flashed on the end of this past July).I have been looking at the Ktuner for awhile and the cobra. I want more power as even SUVs & Trucks these days accelerate as quickly as the si does. Anyway, what to you all consider abuse? My commute involves some highway merging and so forth and most every day I floor it from from 2nd through the beginning of 4th. Most everyday I run through 2nd to 3rd but not to redline but to about 5.5 or so. Most weeks I'd say at least one drive through a curvy road and few round abouts where I am pushing it hard enough that I am at the traction limit with the stock tires. I mean, I bought this car to drive just like the ones before it. I just can't see the value if you have to "baby it" so to speak. That just doesn't make any sense in my world. I don't take issue with a tuner, intake, downpipe, but a $1k+ clutch is a no go for me. So, after all that, those with the tune, are you driving the car at it's limit somewhat regularly, or you just enjoy having an si and for most part, drive like a responsible person that could really just as well be driving a camry?
No clutch issues. I thrash my car... but I don't build high boost levels in high gears. I see no good reason to ever do it in 5th or 6th. The top of 3rd is over 80 MPH. 4th? 100+... and I just don't drive that fast. If you want to accelerate hard, you should be picking the proper gear IMO. If folks want to upgrade their clutch so they can not downshift and accelerate slower by chasing after a torque surge in 5th or 6th gear at highway speeds... well... it's their money. I won't say it's wrong because it's their car and they can use it as they please... but it's a slower way to go about doing it, will put more strain on the drivetrain and it's not a style of driving I've ever done on any of my previous cars and I see no reason to start on this one... when I know it's clutch is an Achilles heel if I allow it to be. I certainly will accelerate gently when I'm cruising on the highway/interstate in 6th... but I'm not going to give it enough throttle to build much boost at all.
Your style of driving doesn't strike me as one that will cause you an issue. I'll happily rev my car to near-redline... holding lower gears longer to accelerate as quickly as possible. IMO... I drive the piss out of the thing. I have zero plans on replacing the clutch... and I drive the same way I always have. I'm not going to change my driving style to hold the car in 6th all the time and refuse to downshift just because the tiny turbo spools early enough that the engine car produce enough power to move at an acceptable click without downshifting. It just seems like a terrible idea... as if your clutch holds... that counter force is still being transmitted back into the engine. My legs don't like trying to pedal my bike when it's barely moving in it's highest gear. I'm sure my rods wouldn't care for it either. That, in my opinion... is abuse.
