Trunk tray for Type R?
Robotaz
Rob
Lexington, KY
2019 Type R
Is there something unique about our car that prohibits us from using OEM or Weathertech trunk trays for the regular hatch?
Weathertech says only a generic one that you cut to fit is available. That one does not have a good lip around the edge to hold liquid. I am using my hatch as a hatchback should, to haul junk. I need a good tray.
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
no it's all the same as long as you buy it for the touring model.
it has a sub on the right side so the tray fro the base model won't be flush and it'd kinda roll up. The oem trunk tray has a section that you can cut out or fold over if you have the oem sub.
Robotaz
Robotaz
Rob
Lexington, KY
2019 Type R
It looks like the Sport tray is the one with the cutout. Do you know if Sport and Touring use the same, which would fit the Type R?
https://www.collegehillshonda.com/instructions/civic/2019/5dr/cargotraysport.pdf
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
If you are talking about the oem part, it's the same trunk tray for every single civic model (at least all hatchback trims). You either just cut out that side piece or keep it on depending on if you have the sub in the back or not.
Robotaz
Robotaz
Rob
Lexington, KY
2019 Type R
One thing I know for sure, is that they aren't all the same. The Sport and Sport Touring have their own, with the part you have to cut off if you have "premium sound". All of the other models use a different tray.
What I can't figure out is if the Type R uses the "Sport and Sport Touring" version with the part that you cut off. Why not just say it also fits Type R if it fits Type R? Makes no sense.
keiothic
YoK
DFW
'19 FK8 CW #22485
Maybe visit a dealership, OP? Perhaps one would be kind enough to let you test fit one from one of the Civics in their lot.
boosted180sx
torrance, ca
2017 CTR, 2016 ILX
yeah, you know what your probably right about the sport trims. The non sport trims doesn't have the hump that the sport trim maybe has due to the center exhaust.
Robotaz
Robotaz
Rob
Lexington, KY
2019 Type R
I hadn't thought about that. Probably so.
bluehatch17
bluehatch17
NJ
My sport touring has the type r trunk tray. It would work vice versa.
Honda Civic 10th gen Trunk tray for Type R? 022B65F6-1600-42C3-94D4-3A8C820D7A5F
hobby-man
GTA
Are you sure? Why does yours look so bunched up and creased, especially at the back? Also, any particular reason why you didn't trim the bit near the sub?
Honda Civic 10th gen Trunk tray for Type R? 20190619_143309
Honda Civic 10th gen Trunk tray for Type R? 20190619_143255
Honda Civic 10th gen Trunk tray for Type R? 20190619_143314
bluehatch17
bluehatch17
NJ
I just unpacked it and installed it immediately after getting it in the mail. The fitment is exact and perfect. I don’t mind leaving that little trim piece, never see it, doesn’t bother me. It’s more protection basically.
hobby-man
GTA
Ah ok that makes senese
FiveFingerCNTpunch
Lori
Pittsburgh PA
2019 FK8 type R - 2020 civic si
Do you know if the civic tray in my SI will fit the type r ? I’m buying one tmw and want to take my floor mats and trunk tray
sLing
2019 Type R
Probably not or it would not be a great fit. You're going from sedan/coupe to hatch which have completely different dimensions.
Byron Sexton
DMV
2006 Mazdaspeed6, 2020 Civic Type R SGP #36784
Lol i brought an eBay knock off that fits like a glove to me, but I'm cheap like that
