1.5T Tranny fluid change?
Digity
Jason
Norcal
2018 Hatchback Sport-16 Pilot-90 K5 Blazer
Going to drain and refill my manual with amsoil synchromesh. Is this ok or does it need to be flushed at dealer to switch over. Sounds like refill is approximately 3.8 qts?
JT Si
Place
Car
WHOAH THERE the manual transmission is 1.9L/2.0Qt. No flush is necessary, remove the fill plug, remove the drain plug, let it drain real good, then reinstall the drain plug and pour two quarts in.
If you are extra paranoid you can check the fill level hole, but for me (being thorough about letting it drain) each time 2 quarts has come out so I've just poured two quarts in.
hobby-man
GTA
3.8 qt is the engine oil capacity btw
Digity
Jason
Norcal
Oh my. Thx. My local auto store told me 3.8. I thought I also read that on this forum. Maybe for cvt? Anyways I’ll stick with 2 and check fill level hole. Will my manual tell me where it is or can you describe location. Thanks.
hobby-man
GTA
Oh yeah, for the CVT it is like 3.8-3.9 Qt
JT Si
Place
Car
It's a plug on the front of the transmission. Not only is it kind of a pain to get to, but it has its own special crush washer that needs replacement if you pull it.
Most of the people here have just drained and filled with 2 quarts and ignored it. A few ounces over on MTF probably isn't going to do anything bad.
Here's the service manual procedure showing the level check plug.
Honda Civic 10th gen Tranny fluid change? 1618588153755
Digity
Jason
Norcal
Perfect thx. Do you know if the crush washer is the same size as oil drain plug.
JT Si
Place
Car
No, the oil drain plug is a 14mm washer. The transmission level check plug is a 6mm washer.
It looks like it's part 90442-R7G-000
Digity
Jason
Norcal
Ok thx
