Dave B
- Dave
- Oct 19, 2019
- 60
- 767
- 468
- Whitby On Canada
- Corvette Z06 (sold) 2020 CW
I know that different tires and set ups require different pressures but was interested in starting a thread on this.
I am aware that using the pressure where the tire is fastest will likely decrease longevity.
I have tracked the OEM Contis, (would not recommend that) as well as Nitto NT-01s and Hankook RS4s. The Contis were run with stock alignment and needed at least 38 PSI. The Nittos and Hankooks were run with neg 2.6 front camber (and about neg 2 in the rear) but otherwise stock suspension. Fastest times with both were with hot temps in the 32-34 PSI range but with the RS4s there was at least an 8 PSI increase for the front tires from cold to hot during a lapping session and this leaves me with cold pressures at the front as low as 24 PSI.
For the time attack series I run in, you get one warm up , 3 hot and 1 cool down laps repeatedly during competition which means I may not see the full 8 lb increase in pressure.
So what have you folks found? I have a competition event coming up soon with new Falken RT660s and would really like to see where I should start.
Please post your tire brand, pressures both cold and hot, and any suspension mods.
