Superthermal
Hello forum!
I have taken and exhausted the possibilities to get decent clear base from a woofer in the stock position of our 2016 Honda touring civic sedan. From the factory, the stock subwoofer not only lacked real base but the plastic rear deck cover in the area of the 3rd break light would rattle uncontrollably against the rear window and lower steel deck. I have taken many steps to minimize this vibration and have had great success in removing the horrible noise in this area… HOWEVER due to the sock steel deck being so flimsy… when I say flimsy I mean that when I placed my Kicker 8” CompRT8 400WRMS sub into this and played a bit of bass the entire deck had a deflection of no less than ½”! I thought it was going to rip apart! WHOOOA! I have since coated it with sound deadener which added to the overall mass of the deck and did a good job to minimize this deflection at most frequencies but due to the weakness and flimsiness of the deck it was by no means gone. I then purchased… now don’t laugh a 12 ¾ x 10 3/8”x 4” 24 gauge steam table pan and mounted this on the underside of the woofer to provide a .23 cu/ft sealed enclosure for the sub.(my sub needs .2 to about 1 cu/ft for a sealed box) This “box” provided additional rigidity to the rear deck to minimize deflection but still not surprisingly did not eliminate it. Due to the movement, still present, the rear steel deck deflects causing the attached plastic deck to vibrate even more as if it was a large speaker causing alternate frequencies than what are desired making tones at specific frequency rates. This drives me NUTS!
Additionally to try to control this "woofing" of the rear plastic deck panel I drilled out the plastic welds of the subwoofer plastic speaker grill and removed it. ( I needed to do this also for the Kicker needs more space for its throw than the stock unit and with it removed the speaker face is perfectly placed..) This is a horrible design and has a perforation pass through rate of I'm thinking about 40%. Speakers need 60+. So as the woffer woofs (LOL) the plastic is pressed away from the woofer face due to the air trying to bleed through the plastic grill, the air is then sucked back through causing it to cavitate back and forth. Since removing this the problem is much better but the bigger problem is the speaker being mounted on what is just a little better that a piece of cardboard or is it silly pudy? or is the metal just painted plastic and no one told me?
The only way I can see getting the vibration out of this rear deck is to massively reinforce the steel deck using who knows what. More steel? Angle iron? Bracing between the wheel wells?
I have considered removing the sub entirely from the deck and using a subwoofer enclosure that holds the speaker in the trunk and directs the air movement up through the removed woofers hole. This would remove the weight vibration of the speaker when it is doing its thing so only air/sound would pass through this area. However, this is undesirable due to loosing trunk space which is a priority for me. I can’t stand base that is hidden away in a truck. Muffled and missing its…. Definition. I am beside myself that the steel on this car is so flimsy. My self tapping screws go into this stuff like butter hardly turning a full rotation before sinking in. Wow. If I had considered this is where I would be I would have purchased a 10 or 12” sub and gone for the directed woofer method. Still considering what to do. Anyone else run into this?
