To those who installed an HID Kit, where did you put your ballast?
Israel
Israel
California United States
It sounds like you hooked positive to positive here. Those bolts on the front of the fuse box hold the wires that power the fuse box directly from the battery. If you follow the wires off those bolts, they lead right to the + side of the battery.
Do the ends that plug into your ballast look like that, or are they two wires completely encased in sleeving? They may have updated the harness so that you only hook one ground up at the battery instead of two points on the body closer to the ballast.
Snoopysir i got the morimoto kit on the instructions says positive connect to the positive terminal of batt. And negative to the megative terminal of the batt. Would that work too?
Israel
Israel
Yeah they updated the harness now it comes with one negative to hook to the battery terminal and positive to battery terminal
