Swiper185
- Dec 17, 2015
- 35
- 17
- Long Island
- 2016 Honda Civic EX-L Sedan
Not to sound like an ass, but wrapping something hot in something that is flammable sounds like a terrible idea.
The ballasts are made of metal because they act as heatsinks - you want to affix them to metal, to DISSIPATE heat; not wrap them in insulating cardboard and absorb all the heat back into the ballast.
Think about what you're doing. You're trapping in heat in something that gets hot anyway - not only are you impacting longevity of the ballast (heat and electronics don't mix well), but you've also created a fire hazard.
In my previous vehicles, I'd stick them on the inside of the fender with some 3M double sided tape. You can also put tape them on top of the front bumper bar (the metal piece). They've held up fine for over 5 years.
I would strongly recommend you re-place the ballasts. Also, please use electrical tape and not masking tape...and don't put something that can get hot on top of the fusebox.
Same, I used a 55w 6K HID from DDM on my 2009 Honda Civic. Used it til 2016 up to the moment I totaled my car in an accident.I've had $25 kits, and $125 kits. The only HID kit I ever had that was consistent and without issue was the DDM kit I got. No flicker, no issues ever, had it for a while. Can't go wrong, their kits are affordable and they have a warranty. Mount the ballasts so they stay cool
Did you have to use any relay harnesses? By any chance do you have any pictures as to where you mounted the ballasts and the wiring?S
The two posts on the fuse box are direct connection to the positive battery terminal, and any mounting point to the body is negative ground. The points I attached too are essentially direct connection to the battery.Did you guys manage to get this wired to the fuse box? I'd like to avoid having wires going directly to the battery (looks ugly), but I was unable to get the configuration in @Snoopyslr 's thread to work (I matched his attachment points on the fuse box for positive and negative exactly). It only seemed to work when hooking the positive and negative wires up to the positive and negative terminals of the battery directly.
While I can't definitely be sure, I can tell you that to make it work, I did the following. First, I took the wire loop that I had attached underneath the rightmost of the two screws on the front of the fuse box (referencing your picture) and attached it to the screw on positive terminal on the battery. At this time, I left the wire loop attached underneath the screw directly to the right of the fuse box where it was (I believe that this screw is the fuse box mount). Tried to power things up, and the lights did not work. I then moved the wire loop from under the fuse box mount to the screw on the negative terminal of the battery. The lights fired up no problem. While I am unclear on which mount was the problem, I do know that I moved the wires that I had attached to the screws on or near the fuse box that you had indicated were good for positive and negative, and transferred them to their respective polar positions on the battery. I suspect that the issue may have been the ground, though I don't know why it would have worked for you and not for me.The two posts on the fuse box are direct connection to the positive battery terminal, and any mounting point to the body is negative ground. The points I attached too are essentially direct connection to the battery.
Are you sure you didn't have the wires on the ballast/relay backwards?
On a related topic, I also noted that you had indicated grounding points for the ballasts themselves. The instructions that came with my Morimoto H11B HID kit had only mentioned attaching the negative wire loop stemming from the HD relay to the negative battery terminal to serve as a ground. Would I also need to ground the ballasts as well? If so, how would you recommend that I do this?The two posts on the fuse box are direct connection to the positive battery terminal, and any mounting point to the body is negative ground. The points I attached too are essentially direct connection to the battery.
It sounds like you hooked positive to positive here. Those bolts on the front of the fuse box hold the wires that power the fuse box directly from the battery. If you follow the wires off those bolts, they lead right to the + side of the battery.First, I took the wire loop that I had attached underneath the rightmost of the two screws on the front of the fuse box (referencing your picture) and attached it to the screw on positive terminal on the battery.
Thanks for your write and and for your feedback - they were very helpful.
Ah, I see. My kit does not look like that - on mine, there is only one grounding wire coming off of the HD Relay. The ballasts themselves only connect to the ignitors. I suspect that, for whatever reason, my attempts to use that fuse box mounting screw as a ground did not succeed. Do you have any alternate recommendations for screws or bolts that could be used as grounds?It sounds like you hooked positive to positive here. Those bolts on the front of the fuse box hold the wires that power the fuse box directly from the battery. If you follow the wires off those bolts, they lead right to the + side of the battery.
Do the ends that plug into your ballast look like that, or are they two wires completely encased in sleeving? They may have updated the harness so that you only hook one ground up at the battery instead of two points on the body closer to the ballast.
Any bolt on the car will be a ground.Ah, I see. My kit does not look like that - on mine, there is only one grounding wire coming off of the HD Relay. The ballasts themselves only connect to the ignitors. I suspect that, for whatever reason, my attempts to use that fuse box mounting screw as a ground did not succeed. Do you have any alternate recommendations for screws or bolts that could be used as grounds?
Strange, swapped the positive and negative wires loops back to fuse box and fuse box mount screws today and the lights work perfectly. Oh well, I'll chalk it up to Gremlins and move on.Any bolt on the car will be a ground.
Does our car have a left to right adjustment? I ask because after installing my Morimoto HID's, I can clearly see the left headlight beam pointed diagonally towards the right. I know that a slight tilt is common to prevent blinding oncoming drivers, but it seems to be pointed at a spot that lines up with the midline of the carBumping this thread. I successfully installed my DDM 35 WATT H11B 4300k kit in my Si today. I had this kit on my 2014 Accord for 3 years and easily expect to get 3 more years out of it in the Si.
For anybody on the fence on HIDs, this is a very easy install. Happy to answer any questions.
Let’s be clear when we talk lights. Drivers side and passenger side.Does our car have a left to right adjustment? I ask because after installing my Morimoto HID's, I can clearly see the left headlight beam pointed diagonally towards the right. I know that a slight tilt is common to prevent blinding oncoming drivers, but it seems to be pointed at a spot that lines up with the midline of the car
