fohidrift
So have had the EX for about <2 months, mostly weekend driving and just passed the 600 mile mark this past weekend. The alert for low tire pressure came on and so I stopped by a gas station to double check the pressure and to make sure there were no flats/nails. Pressure on all 4 tires came out to be around 40psi. I know the stock tires are supposed to be 32 psi so I chalked up the 40 psi figure to having been on the highway for about a half hour beforehand and also wasn't sure if the gauge at the gas station was just off. So I ignored the issue, hit recalibrate on the TPMS, the warning went away but then eventually the warning came back on again an hour later as I was approaching home. Waited a day for the tires to more than fully cool off and then checked the pressure using my analog gauge and each tire was indeed down to about 29 psi.
Questions for you guys:
1) Have you guys experienced similar drops in psi on these stock tires despite conservative driving and low mileage driven? (Also, temperature-wise here in NY recently, it's only getting warmer and warmer)
2) Do you guys usually inflate at the gas stations using the timed coin pumps or do you guys have a recommended tire inflator you use?
