Thuseefc - Mugen Si
Thusee
Thusee
Thusee
Markham
2018 civic si sedan
Do I need the prl ss line for the clutch and cmc upgrade from eman?
I'll be getting it installed when it arrives here hopefully with the next week so I'm curious if I should order it now.
I would recommend it. Get it all done at the same time.
ManitobaSI
Scott
Manitoba, Canada
2017 Civic SI
How about powder coat or painting the valve cover. I am looking to do that but not familiar with reinstalling the cover in terms of Honda bond, order of torquing or torque amount. I was thinking to buy an OEM replacement so I didn’t have downtime. I wonder also if there is a difference in benefits to powder coating or high heat paint. I’m getting closer to being done performance mods and now I am looking to do some engine bling. Cheers.
Thusee
Thusee
Thusee
Markham
2018 civic si sedan
Hey
Not sure how well powder coat and curing process will work with the plastic valve covers unlike the older metal/aluminum covers, however you can get wrinkle high heat paint and primer and spray it yourself.
Instead of getting a new oem cover find a used one, clean and paint that. Order the valve cover gasket kit from honda and have that ready.
Honda bond is applied to any 45 or 90 degree sharp corners but doesn't hurt to apply a thin layer all around.
Torque sequence with any valve cover i always start at the middle and work my way out in a cross pattern, never had any issues and hand tightened it. Its a 10mm bolt I can't see the torque number being significantly high. Probably 8 to 15 ftlbs.
The only thing that kept myself from painting a cover for my car is the fact that there are so many dam hoses, wires etc running all over it so didnt really interest me in spending all that time to have most of it covered up.
Hope this helps.
suhhh
Kenny
North NJ
Love the build man. Wondering how much you are dropped on those tein coils and how do you like them?
Looking at a coilover upgrade down the line and I see they include the cancelling unit for adaptive dampening so I'm interested in them
Thusee
Thusee
Thusee
Markham
2018 civic si sedan
I think i'm dropped about 1.5 inches all around, I have about a 1 finger gap. I don't rub at all with my current setup.
Tires are 245/40 on 18x9.5+38 so the slight stretch clears the fender line and never had issues. Front has about a negative 1.5 degree camber and rears about negative 2.5 degrees of natural camber (no camber arms). I do want to go with a slightly more aggressive tire/wheel setup so will be raising the car up when the time comes. I still have about 1 inch of drop available.
Overall I absolutely love the Teins, amazing for street driving (i haven't tested them on the track yet but feel they may be a little on the softer side)
I highly recommend you getting the EDFC controller and motors to adjust damping on the fly, you can see POST 101 for details on that. Main reason i recommend this is because the rear damper adjustment is practically impossible to get to unless you jack up the car/take the wheel off even then it might be difficult because of the location.
I have no ADS lights thanks to the included cancellers! I actually didn't know they came with the coils until i received the package. So added bonus haha! Everyone that has driven my car speaks highly of them!
suhhh
Kenny
North NJ
Thanks for the detailed response man! Yeah I definitely want to go coilovers with a flush look, I really like the fitment of your setup, I was previously considering 18x9+35. Definitely need a set of coils good for street and day to day driving as that's where most of my driving is. Will definitely look into the edfc controller, I actually didn't even know they offered something like that. That will definitely save a lot of headaches and time hahah
Cheers bro
Thusee
Thusee
Thusee
Markham
2018 civic si sedan
Whiteline adjustable lower front balljoint!
Probably the only set out in the world for testing out of Whitelines headquarters lol.
These balljoints will be available through @Unity Performance very soon! Onto the product.
Overall build quality is amazing and it is a pretty straight forward install. After install i immediately noticed the steering its much stiffer and feels a lot better. And smoother. Highly recommend this for anyone on stock shocks that want more camber without having the need to buy coil overs. Or if you want more camber than the coils can offer.
Overall very pleased with this product!!!!
I took as many pictures as I can in order to cover each stage. If you have any pictures feel free to ask away!
Tools needed:
17mm socket
17mm box end wrench
18mm socket
19mm flex socket
Desired 1/2inch length extension
36mm axle nut socket
Balljoint separator, hammer, air hammer
Honda Civic 10th gen Thuseefc - Mugen Si 1_20201027_171022
Had to use these jacks on each wheel to raise the car in order to get the hoist arms underneath haha! The Mugen sides hang lower than the oem side skirts.
Honda Civic 10th gen Thuseefc - Mugen Si 1_20201027_171521
Picture of the stock balljoint
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_173607
Remove this cotter pin/clip from the lower balljoint.
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_173937
Remove 3x 17mm nuts under the control arm for the ball joint.
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_173952
Remove 19mm castle nut...as you can see that's not possible.
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_174358
Remove 36mm axle nut
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_174541
Pull out axle from hub and remove lower balljoint from lower control arm
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_174645
Use a balljoint separator tool if you have, or hammer the lower balljoint mounting space or use an air hammer to remove old balljoint.
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_175142
These are the nuts that were removed
- 3x 17mm lower balljoint bolts
- 1 axle nut
- 1 19mm castle nut
- 1 cotterpin/clip
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_180320
These are what were installed
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_180814
Here are some comparison pictures between oem and Whiteline
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_180401
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_180426
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_180615
I installed the castle nut first along with the cotter pin
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_181241
Installed lower balljoint bolt and nut but when tightening I pushed it in all the way for a oem spec install. (Didn't need too much more camber yet)
Used a 17mm box end wrench to hold the top of the bolt while using a gun with 18mm socket to tighten the bottom nuts.
Tightened axle nut to 190 foot lbs.
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_182025
Some installed pics.
Whiteline 27mm front swaybar
Whiteline adjustable stabilizer links set to stiff
Whiteline adjustable lower balljoint
27won bbk
TEIN Flex Z coil overs.
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_185311
Honda Civic 10th gen Thuseefc - Mugen Si 20201027_185801
Unity Performance
Humza
Toronto, ON | Buffalo, NY
unity-performance.com
86salmon
It's Hedley, Hedley Lamarr!
Chucktown, SC
Farsan
Spain
2018 Honda Civic X Sedan Ex
Flood lights!
Here is my latest project... still need to run the wiring but I cut out the panels and mounted the light housing!
Really interested in that. Where will you plug those?
