Thougts about sound upgrade
udihamudi65
Ehud
Israel
Civic type R
Hi everyone,
Would appreciate your thoughts about my build for 2021 type R.
The stock system is 7 inch head unit 180W with 8 speakers (EU version).
main amp+DSP: Audison Prima AP F8.9 bit 8 x 85 W RMS and 4 x 260 in bridge mode (RMS @ 4Ω)
sub amp: Audison Prima AP1 D - 1-channel amplifier 1 Ch @ 4Ω: 310 W x 1, 1 Ch @ 2Ω: 540 W x 1
3-way front stage: Hertz ML 700.3 – 70 mm Midrange+ Hertz ML 280.3 – 28 mm Tweeter+ Hertz ML 1650.3-165mm woofer
rear speakers: Hertz CK 165-16 cm Speaker Composystem
subwoofer: JL Audio 10W6v3-D4
would like to mount the mids and maybe also the tweeters with theese:
https://www.ebay.com/itm/274321270399
integra15
Ann Arbor
2017 Civic SI
I think you are going to spend a lot of time figuring out the proper signals.
In the US market, each of the speakers has its individual amplifier channel so finding new equipment to match is tough. (10 channel stock amp)
In setup I reduced the system from 10 to 6 channel. I retained the stock amp for the center, have a 4x60 watt amp for front and rear, and have 1x150 for the subwoofer.
udihamudi65
Ehud
Israel
Civic type R
  • #3
Isn't that something the installer should be doing with the DSP?
udihamudi65
Ehud
Israel
Civic type R
  • #4
The tweeter size in this setup is 1.38 inch. will it fit in the OEM tweeter location?
another option is to go with a hertz 1950.3 2-way kit, it has a 1 inch tweeter, the same mid woofer and add just the midrange.
udihamudi65
Ehud
Israel
Civic type R
  • #5
OK, just found out that the OEM tweeters are 1.5 inch so I guess it will be fine.
Another question is for a good sound stage, it is better to have component speakers in the back or just coax, or maybe stay with OEM?
integra15
Ann Arbor
2017 Civic SI
Yes I believe all your equipment is high end so there should be enough options. But for example one problem is the Honda factory setup sends only midrange to the door speaker and only high frequency to the tweeter. You might need to find a way to sum up those signals and feed it to your component speakers. Additionally there is a low pass crossover on all speakers except the subwoofer.
However if you have a competent installer they should be able to get it set up and sounding good.
integra15
Ann Arbor
2017 Civic SI
I would not personally do a 3 way setup upfront. The system is already fairly complicated, and I like to have a factory look with mounting only a mid woofer in the factory door location and a tweeter in the OEM location.
