BriteBlue
- Jul 6, 2018
- 30
- 847
- 401
- Illinois
- 2018 Civic EX-L
This is a short version of my experimentation & trials.
I read good reviews about the BAFX OBD2 Bluetooth reader so I got one on Amazon. Then used the Torque Pro app which said it could use either GPS or the vehicle’s speed sensors for speed readouts.
I was getting very slow 0-30 & 0-60 times. Also had to overshoot the 0-30 timer & get to about 43mph in order to even get a reading, & go to about 75mph to get a 0-60 timer reading. And the 0-30 and 0-60 were both 12.6 seconds on the same run for example. Obviously something was wrong.
I don’t know how the app chooses which source (ECU or GPS) to use for the speed when doing a 0-60 run, but apparently it wasn’t choosing properly. I manually turned off the GPS in my tablet & smartphone that I was using. The app then had no choice but to use the speed from the vehicle's sensors/ECU. That solved the problem.
I first played around with this setup on the Civic. The end result was I did four 0-60 runs, 2 on one day & 2 the following day.
7.67, 7.43, 7.38, 7.38 seconds.
Obviously I had no idea how accurate this was. But my plan from the beginning was to compare times with my other car which has a data logger. I did several 0-60 runs & tried to cover a range of times. The car's data logger time is the first column & the OBD2 reader with Torque Pro is the second column.
Car -- OBD2
5.4 -- 5.40
5.3 -- 5.26
9.7 -- 9.65
6.8 -- 6.85
8.9 -- 8.88
8.3 -- 8.30
Rounding off the OBD2 readings to one decimal point they are the same as the car‘s data logger, except for that 6.85 sec time which rounded off the other way. It's anybody's guess which is the more accurate. A tenth of a second accuracy is all I’ve ever seen in any published stats for 0-60mph, so rounding to one decimal point seems OK with me.
I’ll have to try the Civic again when the roads are cleaner & hopefully get a bit closer to 7 seconds. There were a couple times when the Traction Control light briefly flashed when taking off at WOT. Even though the road looked clean, apparently there was a bit of residual salt or dirt in some areas left over from a somewhat recent snowfall. The cold weather probably didn’t help with traction either, letting hard tires spin on cold pavement.
Car -- OBD2
5.4 -- 5.40
5.3 -- 5.26
9.7 -- 9.65
6.8 -- 6.85
8.9 -- 8.88
8.3 -- 8.30
