TheDeliSauce
- Jordan
- Jan 14, 2021
- 2
- 68
- 91
- Ohio
- '18 Civic SI
- Build Thread
- Link
- #16
255/35 (35 better fit than 40 in this case) would look a little goofy on 8" wide wheels. I'd recommend going 9-9.5" before going to 255/35. My TSR-X 18x9.5 are only 20.45lbs each, so I don't think you'd be sacrificing much weight.Okay, cool thanks! I'm running Enkei TS5 18x8 +40 and 245/40/18 MPS4S. I got these wheels and setup to prepare myself for the 27won BBK. I also wanted to keep the weight at/under 20 lbs for the rim and push it out a little bit to fill the space a bit more. I never rub, with the exception of the driver side driving over this roller coaster bumpy road in my area. Which, thankfully I avoid. I also, notice I have more space in the rear. I was thinking of running larger tires in the rear, like 255/40/18 when it comes time to swap out to new tires. What do you think about that? Would that affect handling in a negative way? Would that be ghetto? lol I have no room in the front. I can barely stick my finger between the inside the wheel and fender. I'm also lowered on Eibach Pro kit.
I suppose in the future, I could get wider wheels, but move the offset more positive.. I just wanted to see how this setup is for daily driving. I want to keep the rim weight at 20 lbs or under for handling and performance. I don't want boat anchors. There is going with a staggered setup vs a squared. Just things that are swimming in my mind now.
