The Tuned Civic X Reliability Survey
  • #406
TUNED CIVIC X RELIABILITY SURVEY STATS (as of 2/15/20)
Total tuned participants: 198
Total tuned miles driven: 2,844,000 (estimated)
Tuned cars with major failures: 5 *
Percentage of tuned cars running reliably: 97.4% **
Transmission type: CVT (63); Manual (135)
Hondata used as tuning device: 50
KTuner used as tuning device: 161
JB4 used as tuning device: 1
Pro custom tune file used: 40
Most used non-base tune: TSP Stage 1 (69)
Most tuned vehicle: Civic Si
Most used fuel: 93 octane (103)
Popular mods: PRL Cobra, K&N drop-in
* 2 cars had a failed CVT. 1 car had faulty injectors and a blown head gasket. 1 car blew an engine running an E35/meth setup. 1 car blew an engine on the racetrack.
** There were minor issues reported here and there with the stock clutch, one suspected injector issue, some fuel trim and knock control funkiness depending on intake and gas used, etcetera. None of these issues were major.
Acraig3
Alex
Denver, Co
2017 civic coupe, 1992 Acura integra
Vehicle: 2017 Civic EX-T coupe
Total tuned time: 24(ish) months
Total tuned mileage: 25,000+ miles
Tuning device(s) used: KTuner V2
Tunes used: custom tune from Brent @PFI speed (260whp 340lbft)
Fuel used: Full pump E85
Additional engine mods: Redline 360 catless downpipe, no name intake, PRL flex fuel sensor, full 2.5 inch custom exhaust, hasport lower mount, clutch master's fx350 and single mass flywheel
Problems/issues: Blue smoke from turbo seals (i.e. turbo overspin and caused failure to oil seals)
Driving style: Hard mostly, in power as much as I could be.
Tuning experience notes: Went very well considering the car made 340Lb-ft and 260hp to the wheels. Only issue was turbo seals. Had a blast with the car, ended up selling to fund a 2019 civic Type R that I will be tuning using hondata in the near future.
@6000ft elevation
Cheers
  • #408
^ Thanks a lot for the detailed survey. You were putting down some serious power.
Trialsguy123
2019 Civic X HTB 1.5T
Vehicle: 2019 Sport Hatch CVT 1.5T
Total tuned time: 1 month
Total tuned mileage: ~1000 miles
Mileage: 12,000 miles
Tuning device(s) used: KTuner v1.2
Tunes used: Dual calibration, see photo
Fuel used: 91-94 octane
Additional engine mods: none
Problems/issues: A weird smell after heavy acceleration, and sometimes transmission jerk\surg. I am getting ready to flash back to stock because I think it is having bad affect on CVT.
Driving style: Mostly chill driving, slightly spirited, especially on highway. WOT at least once a 3 times a week.
Tune experience: Little experience, read gtman's thread on recommendations.
  • #410
Not sure what that "weird smell" could be other than some funky rotten egg WOT smell which is normal really. With your basically conservative setup, your CVT should be just fine.
cruisencode
Orlando, FL
2017 Civic EX Hatchback
Have you upgraded to version 1.0.9.5 of the KTuner software? If not, upgrade the KTuner software and then re-upload the tune. This helped others with similar "jerking/surging".
Check out this thread: https://www.civicx.com/threads/hesistation-stutter-at-low-rpms-tweaked-starter-21-ktuner.44508/
Trialsguy123
The smell is almost like burning coal. The first time it happened I thought it was the outside air. But then I realized it is always after hard acceleration. It tends to linger for about 5 minutes. Yesterday, I was on the freeway and hit WOT to pass about 4 cars before exiting, I hit about 85, then exited. I then smelled it and made a 15 minute stop at the hardware store. When I restarted the car and was backing out I smelled it again, and the car felt like the brakes were on as I was backing out. It felt fine when I put it in drive.
Does the attached photo show what a typical Ignition Base map is supposed to look like?
  • #414
Not normal as in all the time but you can get that sulphur smell at WOT from the cat on occasion. Bad gas maybe?
Or I could be wrong. :cool:
highroller
U Hash
Pak / NY
Civic 1.5 Turbo
Vehicle: 2017 Sedan CVT 1.5T
Total tuned time: 2 months
Total tuned mileage: ~1200 miles
Mileage: 26,000 miles
Tunes used: Dual calibration, TSP Stage 1 map 3
Additional engine mods: CAI RACE MAF, SI TURBO, DP/FP
Problems/issues: traction issues at launch. Higher than usual kcon.
Driving style: Mostly chill driving, cruising at lowest possible revs. WOT at least once 2-3 times a week.
Tune experience: car is responsive and fun to drive
SilverArrow
Milan - Italy
Honda Civic X 1.5 T. Sport
Sometimes
sometimes I smell this, also driving normally without WOT
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
Vehicle: 2017 Civic Sedan (EUDM)
Total tuned time: 22 months
Total tuned mileage: 30,000+ miles
Tunes used: KTuner Starter21, TSP Stage for the non-Si, My custom 24psi tune
Fuel used: Mostly Shell V-Power 98RON
Additional engine mods: Mishimoto Intake
Problems/issues: None
Driving style: Slightly speedy with aggressive bursts from time to time.
Tuning experience notes: I've had all my turbo cars tuned. This is the first time I am using a tool on my own. Returning the car to factory from time to time for the dealer service visit reminds me how awesome tuning this car is :)
Update with a fresh dyno after a lot of street WOT logging and fine tuning … not bad for a stock turbo …
  • #418
Nice work. So this is your 24 psi self-tune?
Am I reading that right? 223 hp and around 265 lb/ft of tq? That torque curve looks fantastic.
GixxerMKD
Baze
Macedonia
Honda Civic 1.5 Hatchback Sport 2018
Is this just with parameters change in ktuner starter 21map?
varge
George
Greece
Nice work. So this is your own, self-tune?
Yes, it's my own tune after a lot of logging and experimenting.
It's a dyno plot and numbers may vary from dyno to dyno, but compared to my first tune my curves are a lot flatter, I have a little less torque pre 3500 now and a much beefier top-end. My first tune had a 211whp spike at 5400 to fade down to 190whp by 6400 rpm (typical for a tune based on the 21 starter). I have tried countless boost target maps to try and figure a steady torque / power band. The tune can be further refined but there is not much point in going after the last 2-3whp :)
No, it is a complete custom boost target map, with tuned MAF scale and custom ignition tables
