The rev hang......
type_r_wannabe
Matt
2018 Honda Civic Si Coupe WOP
I'm a new owner as of wednesday of a 2018 si coupe.
I obviously test drove the car but one thing i'm noticing that takes away from the driving experiance HUGE is the damn rev hang....from 2nd to 3rd its honestly unbearable. My foot is on the clutch for like 4 seconds waiting for the revs to drop to an area for a smooth shift. I'm big on that when driving around normally.
Is hondata/ktuner truley the only way out of this problem? I have the standard 3 year warranty and wasn't going to do it until after, but it feels like its taking away so much from what the driving experiance COULD be....
coopermidnight
Brandon
19 FK8
KTuner (and Hondata, I'm sure) does do the trick for sure.
In case you're under the same mistaken impression I was, though, a tune only affects the throttle closing delay. Your revs will start to drop immediately after clutching in, but they'll still drop slowly.
charleswrivers
Charles
Kingsland, GA
There is no other way other than a tuning device to remove 'rev hang' though... as it's a software based slower closure of the throttle than what your foot it inputting via the pedal to allow for a more complete fuel burn for emissions. That can be eliminated.
It helps, but the tiny engine with the heavy flywheel will always have the revs fall kind of slow. The 9th gens had rev hang bad, but by removing it through a tuner, the engine was better suited to allow revs to fall. Removed, it's much better to me now, though still a little slow for revs to fall.
DC
Harley Davidson, Mustang GT
I know its vastly more expensive but if there is a hint of lag after reprogramming it, has anyone felt a difference if they replaced the flywheel with a lighter one?
davemarco
@charleswrivers comment regarding the revhang delete using a tuner is the most accurate. The revs will always fall slowly, but they will begin to drop immediately when you step on the clutch (unlike stock, where they can hang in place for several seconds or even climb a bit when you clutch in).
Another member recently also had a lightweight single mass flywheel installed, which likely helps to improve the drop speed. It's not the instant plummet that you'd get on an old school manual, but both improvements would help quick a bit.
privatejet
Texas
2018 Civic Si
Do you need to be in 'Sport' mode for the rev-hang to go away with the Hondata, or does it remove it all the time (as when driving around normally not in Sport mode)?
hawk02
Far away
2017 Civic Si Coupe
That's a choice when you pick your tune
WOPSiWOT
South Carolina
2017 Civic Si Sedan
All the time.
The rev hang delete transforms the driving experience more than I would have thought. Just get a tuning device and get it fixed.
JNRS
NY
2018 Civic Si Coupe
You sound like me when I first got my Si lol. I still hate the rev hang, but I have adjusted my driving style to make it a little more tolerable. The only method I find to work, aside from tuning, is to slip the clutch in between shifts. I know this method is not the best for the clutch, but I feel its better than waiting 3-4 seconds in between shifts. Hopefully, the clutch will last for the duration of my lease :D
DrToothache
North Carolina
2018 Civic Si Coupe
You sound like me when I first got my Si lol. I still hate the rev hang, but I have adjusted my driving style to make it a little more tolerable. The only method I found to work, aside from tuning, is to slip the clutch in between shifts. I know this method is not the best for the clutch, but I feel its better then waiting 3-4 seconds in between shifts. Hopefully, the clutch doesnt have to be replaced before my lease is up :D
I do the same thing when shifting from 1st to 2nd sometimes. I feel like an idiot waiting for the damn RPM's to drop for 3 seconds so this seems to be the only other option other than short-shifting. The rev-hang really shows though when you are doing spirited driving. For casual driving I usually short-shift which hides the issue for the most part. It really makes 1st-2nd a pain in the ass lol.
Vrruumm
2017 Honda Civic SI Coupe
For how much I would like to just get rid of rev hang, I don't think the price of a tuner is worth it just for this change. Not sure if it is just me, but shifting from 1st to 2nd without going above 2500 doesn't enable the rev hang feature.
JNRS
NY
2018 Civic Si Coupe
That might be true. However, if your trying to get up to speed quickly, only reving to 2500 rpm, will not be enough. That is when VTEC begins to kick in (Kidding).
