The Oil Thread
David Harper
Crystal Lake, Il.
2016 Civic coupe
I changed oil once without raising the car but it's a PITA. Now I put it on jackstands. I had ramps but they were too steep and I would have damaged the front bumper driving onto them. Also my car is 6MT so getting it up onto ramps might be pretty scary. Too easy to drive off of the end of the ramps.
Thaaaaat would be ugly.
The Vyzitor
buy a fluid evacuator like a MityVac. Makes the A code oil changes (no filter, just fluid) incredibly easy. Just feed the tube down the dipstick and pump out the oil. Refill. Check the level. Done
Honda Civic 10th gen The Oil Thread 1E0E5403-50AC-46B9-AA06-ABC49E3CCACF
MarcOTT
Marc
CT
Odyssey - Civic - CRV
I agree with the oil drain plug and filter access. Same for a 2.0L sedan. Had to buy low rise ramps to allow my low profile racing jack to slide under to reach the center jacking point behind the engine, What was Honda thinking by relocating the front access center jacking point !
SpringRubber
Virginia
2018 Hatch Sport, CVT, White
I've also heard good things about MityVac. As for me, I just finished building some low profile ramps and tested them out with an oil change.
I measure about a half quart of fuel dilution above the 3.7 quarts that I put in, per this pic showing what I just drained out. About a month ago I had a sample tested (Blackstone) and adding the report here. This was my 2nd oil change (10 months and 6200 miles on this oil), yes a low mileage car with lots of short drives (daily commute is 3 miles each way).
I have to agree with @Gruber and maybe others who've stated Blackstone's calculation for fuel dilution based on flashpoint can be off. Based on volume, with a quart half-quart of fuel in the oil am I not at 0.5 / 4.2 * 100 = 11.9%???? (vs. the 4.3% from the analysis)
fyi: here's my post for DIY ramps:
https://www.civicx.com/forum/thread...-scrap-lumber-strong-enough-for-a-jeep.48415/
Honda Civic 10th gen The Oil Thread 2020-04-23 civic oil volume
Honda Civic 10th gen The Oil Thread 2020-03-19 - 2018 civic HB sport report Pennzoil 0W-20
bigdogpapa
North Carolina
2015 Fit Ex-L CVT , 2019 Hatchback Sport 6MT
Did anyone uses RAVENOL oils?
After a recommendation from a friend with an Audi A7, I did an oil/filter (Honda A01) change recently and used Ravenol 0W-20 EFS (PAO) fully synthetic (SN PLUS/RC). After about 500 miles I think the engine is smoother. Now it is difficult to tell if the engine is running at stoplights. As an added bonus fuel economy is up slightly.
At the same time I changed the MTF also using a Ravenol product (MTF-2). Shifting is noticeably smoother yet more defined and there is less tranny noise at all speeds. I solved the 2nd gear crunch by adjusting the CMC a week or so ago.
From my experience, I would highly recommend Ravenol products but a bit pricey. Both of these oils are available in the U.S. from Blauparts and If I recall correctly Amazon.
  • Like
Reactions: DyM
DyM
Dmitry
Maryland, USA
2017 Honda Civic Si Coupe
Just curious what you mean by "adjusting" the CMC - is there a writeup you were following?
bigdogpapa
North Carolina
Yes, there is an excellent and concise step by step post by Lust.
If you follow it completely it should work for the "2nd gear crunch".
TunaFresh
CA
2024 2.0L
Ravenol uses very little and very high quality viscosity index improvers. It's a good, but expensive choice.
biosses
Japan
Here is my oil analysis, at 30k miles with Mobile1 0w-20 oil since new.
Honda Civic 10th gen The Oil Thread oil analysis at 30k miles
Gruber
Mark
TN
Forgot to pop this up here after my first oil change, the second will be coming soon enough.
I wonder... with only trace oil dilution, as it should be with a 2.0L, why is the 100 ° C viscosity of your oil as low as it is. The Honda Synthetic Ultimate 0W20 seems to be specified at about 8.8 cSt. At 6.8 cSt it is in range, but noticeably reduced after 5600 miles.
The post just above shows 1.5T after 3500 miles on Mobil 1 0W20, and they say the oil dilution is OK at 1.5%, but "keep a close eye on it, to be sure it doesn't reach 2.0% or more, that often shows a problem."
In this case the viscosity is 6.66 cSt, so considering the Mobil 1 0W20's specified viscosity is 8.6 - 8.7 cSt, the viscosity drop in both cases is exactly the same.
So it seems from these two examples that 5600 miles on 2.0L produced the same oil viscosity reduction as 3500 miles on 1.5T.
Of course oil viscosity is not the only effect of oil dilution, but it's a good indicator to monitor.
CTRismybeater
Colorado
2011 E90 M3 & 2019 FK8 CTR
Fuel shear usually equalizes at around 1,000 miles, often less, in my experience.
absolude
GTA
KW SC 2007 CSX Type S, 2023 PWP Si
I haven't seen any UOA evidenced that Amsoil or any other boutique brand holds up better than Mobil 1 or Pennzoil.
True. The transmission on my other car crapped out when using highly recommended Amsoil MTF too.
Jimmou
Jim
Fresno, CA
2019 Civic SI Sedan
Here's my oil report on my '19 SI. After a grueling hot summer here in central California, I was wondering if I needed to make the switch to 0W-30 oil next summer. Since the report looks great I'll just continue running Pennzoil Ultra Platinum 0W-20.
SDAlexander8
Indianapolis, IN
I’m convinced oil dilution is a non problem as long as you actually drive your car more than 3 miles a day.
