Dave B
- Dave
- Oct 19, 2019
- 60
- 767
- 468
- Whitby On Canada
- Corvette Z06 (sold) 2020 CW
If you plan to use the middle setting which gives you about -2.7 camber as your goal, take the pins out. If you are planning to use the more aggressive setting that will get you likely to a max of -3.7 or so, there is no need to pull the pins as you will likely want to back track on what is a very aggressive negative camber setting. I used the middle setting and definitely pulled the pins for an average of - 2.65 degrees on stock springs. There was slight discrepancy between sides with only -2.5 driver's side and -2.8 passenger side. I certainly didn't notice this driving and would be hard pressed to shift my subframe for a total of 0.15 degrees. If I were using a softer sidewall tire like the Yoko A052 or a full race slick, the more aggressive camber setting may be more ideal but I am happy with the middle setting.
