Virginia Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8)
teders
Ted Dorosheff
Mclean, Virginia
2017 Honda Civic SI
Tein S-tech lowering springs, about a 1.4 inch drop F/R - $120
Eibach Prokit 10mm hubcentric spacers with extended lugs (part# s-90-6-10-012) - $100
Hawk HPS 5.0 Front brake pads for the FK8 (also compatible with the genesis coupe OEM brembo calipers) - $120
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20201012_170343[1]
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20201012_165812[1]
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20201012_170806[1]
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20200927_192352
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20200927_192400
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20200927_192423
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20200927_192500
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20200927_192502
Honda Civic 10th gen Tein springs, 10mm eibach spacers, HPS 5.0 pads (FK8) IMG_20200927_192520
teders
teders
Ted Dorosheff
Mclean, Virginia
2017 Honda Civic SI
Bumping, still available.
teders
teders
Ted Dorosheff
Mclean, Virginia
2017 Honda Civic SI
Do you need a camber kit for those springs for alignment?
No, I ran them without the camber kit and you get a pretty close to stock alignment, with just a tad of neg camber in the rear. Less than 1 degree of camber, which is what I actually run on track now.
Syntek
Los Angeles, CA
2019 PWP Civic Si Sedan
PM Sent
teders
teders
Ted Dorosheff
Mclean, Virginia
2017 Honda Civic SI
Keeping the pads. As of now the only things available from this listing are the springs.
