RBrackett
- Ramon
- Mar 7, 2020
- 14
- 329
- 209
- New Orleans, LA
- 2019 Type R Aegean Blue Metallic
yea i plan on getting the new PRL P600 when it drops in the future.My feed to the port injection is T off the feed line to the HP pump ~75 psi rail pressure. Im betting i run out of pump before i make any real power. I hate cheap chinese style pumps-aero, dw,grams,hondata.. seen them all fail.. new, used, 2 weeks old.. you name it. i think i will continue to use the factory pump and convert it to low low pressure feed and run a surge tank with the built in pump/ regulator similar to Ty. A Radium surge tank with a 450 walbro should feed everything i can make with a 7163.
wait so its T'd before the HP Pump? so PI is being fed directly from the LP intank Pump?
i've never messed with PI in the past so i might be wrong/overlooking something, unless going for monster numbers, would upgrading to the XDI HPFP and T the PI off of that be Viable? basically have the upgraded HPFP feed both primary and PI injectors? (idk the duty cycle on it so might even fun out of fuel that way too)
