Switching some interior parts to leather
VAN
Grand Rapids MI
2020 Civic Si Coupe
I'm trying to switch some of my Si Coupe interior pieces to leather. Please help me verify part numbers. I'm a noob when it comes to ordering parts.
Thanks in advance.
justasimpleman
socal
2020 SGP EX hatch
That’s the correct numbers for the center. I’m not sure about for the doors, it could be.
McDavid
Civic LX
Has anyone tried the fake leather ones, that you basically put over the current armrests?
They anygood?
Driver56
RVA
2018 Civic SI coupe
Looks correct to me, but I only swapped out the door pieces (it's a different process than the sedan, I think most videos show sedan).
DaiLo
19 Civic Hatchback Sport CVT
They anygood?
I did my door cards, armrests and center console. I would say they're ok. You can see where the seams are in the armrests/center console if you're looking closely and the tuck is not as perfect as I would like in certain spots. It's also not as tight as I would like even after trying for hours to make it all seamless. I also had to replace the front passenger door card as the stitching caused there to be extra material where there shouldn't be which made tucking impossible without wrinkles in that area. The seller replaced them no problems.
Verdict is it looks great at first glance and worse the more you start to analyze it. Most people getting in the car will probably not notice the trouble spots unless they're really looking hard. But for $90 CAD compared to what OEM ones cost (plus I like the red and black stitching) or what an upholster would charge, it's worth it imo.
McDavid
Civic LX
Looks good. Does it affect the movement of centre console, I've seen a couple of vids where it was hard to slide back n forth after install.
thatcaveman
Josh
Nevada
2016 Civic Coupe EX-T
Yep. Those are the parts. Just did the install this weekend on an EX-T coupe and it wasn't that bad.
Went with the 2019 Insight parts for the center console since it was a bit cheaper and more plush for your elbows but they are the exact same parts. Since I have the beige/black two tone interior, the grey stitching of the center console pieces fit perfect.
DaiLo
I mean I can feel a bit more friction but it doesn't interfere with the movement enough to worry about it at all.
