n2da2nd
It's Senor Bane to ya
- Nam
- Mar 23, 2018
- 27
- 1,280
- 1,840
- DFW
- Website
- www.instagram.com
- 2018 Civic Hatchback Sport Touring
- Build Thread
- Link
- Vehicle Showcase
For those who are wanting to wire the sequential turn signal side markers to LED headlights assembly but don't know which wires are the turn signals wires, here are the steps that I did to mine.
1. Unplugged the headlight plugs to find the correct wires for the turn signals by feeding the side markers' wire thru each hole on the back of the headlight plugs. Each time, you have to turn on the turn signal to test. The correct wire will light up the side markers on both parking lights and turn signal lights. This is the most important step that you must do in order to wire everything correctly and properly.
2. Once I found the correct wires, light blue on the driver's side and green on the passenger's side on my 2018 sport touring hatchback, I use a displacement/splice connector to splice and connect the side markers' wire and the car's turn signals wire.
3. Use the electrical tape to securely cover the exposed wires before tuck them back into the looms. Turn the car on to test the parking lights and turn signal lights afterwards. You have now successfully completed the wiring of sequential turn signals for your LED headlights.
The side markers can be purchased from the Amazon store here
www.amazon.com/shop/civicsocialclub
Disclaimer: even if your car had the same colored wires as mine, I would highly recommend y'all test them first to make sure they are the right wires. This post is only an informal post to document the steps that I did on my car. Under no circumstance that this is a guaranteed way to achieve the similar result.
