Swift Springs Civic Si
angry_lime
Kevin
2018 Si Coupe
Finally found some time to install the springs. Normal driving feels almost exactly like factory but cornering feels so much better. Swift did an amazing job with these :bow:
Lunarsilver17
Dublin, va
2017 Civic Si coupe
These springs make the car at home on curves, and the ride is a little stiffer than stock but I believe will be fine on the streets.
fk84life
Lance
San Jose, Ca
2018 FK8 Civic Type R
How much have you guys been picking these up for, my buddy got them from AMR Engineering for like 300 shipped. Just curious.
Chief lazy leaf
Joshua
Grand terrace
2018 civic SI, 2001 mr2 spyder, 1982 Toyota coroll
Did mine this weekend too. Definitely glad I waited for swift.
Chief lazy leaf
Joshua
Grand terrace
Waiting on tires for my new rims but with the fender tab pushe'd up it shouldn't rub. No camber kit yet.
Lunarsilver17
Dublin, va
2017 Civic Si coupe
how long for the springs to settle,? Mine suspension is making some very light noises when parking (turning at slow speed), which is weird because the car made no noise on the test drive right after install, or maybe i just didn't notice, like I said, very light noises. I havn't got an alignment yet, trying to find somewhere that will install camber arms.
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
I haven’t gotten mine aligned yet and it’s been about a week. Drives super straight. No vibrations or noises. Getting it done this upcoming week.
Question, as I’m new to the lowered game-
Can any tire alignment shop take care of this and do they just follow standard alignment specs for Honda or do I need to specify anything?
Lunarsilver17
Dublin, va
2017 Civic Si coupe
Thats a good question. The Honda service manual is only available online and you have to pay for access. I would think a shop other than a dealership would have to pay for the access at least the first time. Specs are in a thread on this site that you could take with you if you wanted to make sure they are using correct specs. I think you should try to meet the factory specs for street applications IMO.
Chief lazy leaf
Joshua
Grand terrace
Not much is adjustable with stock parts when lowering. Just the toe, so I'm thinking any shop could do it for you. The pic I posted earlier was from Honda for my alignment. Also got to the track this past weekend. Springs felt great. Only wish I had more camber all the way around. Got to see 3 other 10th gen civic's out there and you could tell they weren't as level on corners.
Chief lazy leaf
Joshua
Grand terrace
Anything special to do alignment?
Nothing special is needed. Camber isn't adjustable, just toe to a extent. I had a friend at Honda do mine and what I posted is the best he could do to get the wheels straight. This was just springs. Next step is buying stuff to adjust camber.
ebatr24
Oregon
Camber has some adjustment upfront, you need to remove the pins near the strut tower. There is a thread somewhere around here on how to do it that also contains the alignment specs for a CTR/Si and also the regular civics. I was able to squeeze a little over a degree of negative camber up front which really helped turn in and grip around a turn. I will post a link shortly.
EDIT: here is the link
https://www.civicx.com/threads/how-to-adjust-front-camber-on-a-tenth-gen-civic.15715/
