Mike2020si
- Michael
- Jul 25, 2020
- 18
- 109
- 37
- Los Angeles
- 2020 Honda Civic Si Sedan
Finished up the car installing the swift spec r springs. Lowered the car and impacted the passenger side top mount nut to the strut. Everything went fine and I torqued it down to spec. Now to the drivers side, I impacted it tight and it spins with the strut thread. When I impact it down, the impact will stop. But when I torque it with a wrench, it spins. Keep in mind I wasn’t using the best impact but it was for sure enough because it did one side. I tried getting a go thru kit to use an Allen key to keep the strut in place when I tighten it. But the bolt is maxed out. Same amount of threading on both sides, but the drivers side just keeps spinning with the shock when I try to use a torque wrench as I did on the other side once the car is dropped.I looked at every single forum and nothing solves my issue, everyone says the strut bolt should torque without the strut spinning once the car is dropped - **bought a go thru kit, also tried RE impacting it - nothing. Same amount of threads on both sides but one shock is spinning with the strut bolt and one isn’t. Nut is tight as an MFr to the shock, but they still spin together when I try to torque. It doesnt just spin easily it’s just when I try to give it a lot of torque with the torque wrench it will spin together with the shock. I was using a dewault torque drill. Do I need a big baller Milwaukee? I would assume the one I was using is fine because it did the other side no problem??
Update: redid the install entirely! Impacted the strut bolt to the strut with a better impact and it didn’t spin with the strut. But when I went to torque it the nut still spins with the strut. There is also a minor clunk Im assuming from this, but Car drives solid as hell I did some major checks no wobbles nothing. Wierd. Well see. Maybe my strut is broken
Thankyou for getting this far :/
