Sway bar / rear engine mount
Andrew
Houston
2019 Civic Sport
Hey guys
I got a 2019 Civic Sport Sedan not to long ago, and am looking for little things I can do to improve performance.
I’ve seen people talking about the sway bar and engine brace, and was wondering if any one could get me some more info and links for specific products?
Thanks Everybody!
You probably do not want a rear motor mount for your application but a rear sway bar can help handing out a bit.
civilian
2019 Honda Civic Touring
Note that the Sport has a sway bar that, while better than the LX, is less impactful than the one found on the EX and Touring.
LX
: 25.0 mm x 4.0 mm (tubular) / 16.5 mm (solid)
Sport: 26.5 mm x 4.5 mm (tubular) / 16.5 mm (solid)
EX: 26.5 mm x 4.5 mm (tubular) / 17.0 mm (solid)
Touring: 26.5 mm x 4.5 mm (tubular) / 17.0 mm (solid)
I Am Noobmaster69
Andrew
Houston
2019 Civic Sport
What exactly would the motor mount do to the performance? I’ve seen people talking about them but I’m still trying to learn about what they do
I Am Noobmaster69
Andrew
Houston
2019 Civic Sport
LX
So how much would an upgraded sway bar help? And are there any you would recommend?
I Am Noobmaster69
Andrew
Houston
2019 Civic Sport
Also would adding a strut bar help anything substantially?
civilian
How hard are you going to drive your Civic? Describe your driving style, how fast you drive, what kind of roads you ride, city vs. country, etc.
I Am Noobmaster69
Andrew
Houston
2019 Civic Sport
Mainly a daily driver, but I live in houston so there’s ample opportunity on our roads to open it up and have a little fun but nothing too crazy. Like I wouldn’t take it on a track but race down the highway at 100+ if it’s empty
racer
Dave
Virginia
2018 Civic Si sedan.
The motor mount mod you hear of is often for drives with tuned engines (more hp) that helps with getting traction by reducing motor movement when starting off accelerating. Likely not something you need to concern yourself with.
Sway Bars (Anti Roll bars) help reduce the car lean when cornering. Depending on how large a bar (particularly a rear bar) that is installed, will quicken the vehicles rotation around a corner. Most often the Autocross guys talk about changing out their sway bars to improve handling (rotation). The safest/cheapest option is often to buy a used bar from someone who is upgrading. So, someone with an EX or Si who is going to larger bars often sells the old bars for cheap. Si bars are thicker and would bolt right on.
