Suspension System ADS Problem
si-ck
TEXAS
2020 Civic SI Coupe
I installed Tein Coiloivers flex z with the ADS error cancellation plugs about 4 months ago.l and I haven’t had any suspension problems or error messages. Until yesterday where I hit a small bump in the road and the “Suspension System (ADS) Problem” error message popped up on my screen. I checked to see if one of the plugs maybe fell off during the bump but they all seemed to be connected still. With the coil over install, I essentially removed the ADS system so the only reason this would pop up is if the error cancellation plugs that came with Teins coil overs somehow messed up? Should I be worried? Has this happened to anyone else?
Honda Civic 10th gen Suspension System ADS Problem 2CF1F284-8EC2-402E-ADFF-2AC6D876FED3
Spunkmire
Southern California
2019 Si Sedan
If this was me I would:
- Remove negative battery cable and let it sit for 10 minutes.
- unplug all the Tien units
- Check for damage around the connection piece, maybe something was dislodged by debris or the wire was nicked?
- plug them back in nice and tight.
- Plug the car back in and see if the error comes back.
I installed these with my MeganRacing coils and I've not had an issue. Installed them last December.
