Suspension setup discussion for the track
ayau
Subaru
Just wanted to start a discussion to talk about suspension setup for the track. Provide your overall handling impressions given your setup. I can start.
Alignment:
Toe: 0 F, 0 R
Camber: -1.6 F, -1.5 R
Caster: Factory
Tires/wheels:
18x8.5 +55
245/40/18 Potenza S007A
Tire pressures (hot):
35F, 38R
All factory springs, dampers, stabilizer bars, etc.
The goal isn't for the fastest lap time. Just trying to achieve a more balanced car and continue to develop better car handling skills. As I build more confidence, I can move away from a less understeering setup and into a more neutral setup.
Front tire roll over is right at the small triangle. Rears aren't rolling over at all. Minimal understeer. Rear never stepped out.
I think I'll try 35f and 40r (hot) tire pressures next time to see if I can get the car to rotate even easier.
In the future, may consider the EVS slotted front ball joints to get -2.7 front camber. Generally, I don't like tweaking too many things at the same time as it's difficult to determine what worked and didn't work.
spyder57
LA
ABP CTR
Alignment:
Toe: 0 F, 0 R
Caster: Factory
Tires/wheels:
18x8.5 +55
35F, 38R
I think I'll try 32F and 40R (hot) tire pressures next time to see if I can get the car to rotate even easier.
Alignment:
Toe: 0 F, 0 R
Caster: Factory
Tires/wheels:
18x8.5 +55
35F, 38R
What wheels did you find that were 18 with +55 offset?
Jotun
Ian
Texas
2018 CTR, 2020 BMW M2c , 2020 LR Defender 110
Good thread! I am in the middle of buying parts and planning my track set up.
Lust
Michael
Bay Area
2019 Champ White Type R
18x10 +40
265/35/18 RS4 / A052
-2 degrees front camber
-2.3 degrees rear camber
0 toe front
1/16” toe in rear but will be moving to 0 toe
Rigid collars, swift springs, guide pins removed, RV6 control arms, toe arms, swaybar, end links and SPC camber arm.
The car handles phenomenally well. I would say the handling is very neutral with an improvement on turn in, steering response, and maintaining the line. Before the car would tend to plow a little bit. The car now is very confidence inspiring.
the car can definitely benefit from more camber. This varies based on driver skill. I personally would want around -3 degrees up front minimum. Best way to tell would be to check tire temps as you pull into the pits. Check inner, middle, and outer part of the tire. Try to get the temps as even as possible across the tire
ayau
Subaru
18x10 +40
0 toe front
What tire pressures are you running? Have you tried increasing or decreasing from the rear tire's optimal sweet spot pressure to increase rotation?
Lust
Michael
Bay Area
RS4s are happy around 34-36PSI hot. I haven’t really played around too much with pressure since my tire wear has been pretty good
Jotun
Ian
Texas
RS4 can handle so much heat. Definitely more of an endurance tire. Gotta love the wear though. I agree with the higher pressure.
apexaddict
Nashville, TN
2020 Civic Type R
I'll play.
2020 Civic Type R
Alignment:
Toe: 1/16" out F, 1/16" out R
Camber: -1.7 F, -1.0 LR and -2.0 RR (need to do the subframe alignment procedure for next time, didn't discover that until after I aligned it)
Caster: Factory
Tires/wheels:
18x9.5 +43 Apex EC7
265/35/18 Bridgestone RE71R
35F, 32R
Suspension:
stock
Impressions:
Balance is OK. The end of every story is understeer, but that's to be expected with a stock FWD car. It rotates a little bit on trailbraking/corner entry (likely thanks to the rear toe out), but once the car takes a set, there isn't much adjustability. It definitely needs a rear bar, though my options are somewhat limited as SCCA TT has weird rules with allowed sway bars in the base class.
I should also point out this is just with VSA "off-off" through long-press of the button; I haven't tried the pedal/brake dance method on this car yet. I'm familiar with it from my 2017 Si, though.
It also definitely needs more camber, but again, with class restrictions there isn't much to do here. Other than spend more money to go into a higher-prep class. :)
ayau
Subaru
I'll play.
2020 Civic Type R
Alignment:
Caster: Factory
Tires/wheels:
18x9.5 +43 Apex EC7
35F, 32R
Suspension:
stock
Impressions:
Thanks for the feedback. I also had similar results. Though I think you've found more understeer than me because you're a faster driver.
I'm looking at possibly the Eibach rear bar. Also, have you tried increasing the rear psi to 38-40 or possibly dropping it to 30? In either direction, you can reduce the rear grip that way.
Oddwayne
Nj
19’ Si coupe & 99 ej6
18x10 +40
0 toe front
Hey bro If you remove the guide pins up front, can you get a bit more camber adjustment or something?
ayau
Subaru
Yes, removal of guide pins will get you about -1.5 to -1.7. I'm guessing @Lust got -2 more because he's lowered on springs.
Lust
Michael
Bay Area
yep -2 with pin removal and swift springs
apexaddict
Nashville, TN
2020 Civic Type R
I actually have an RV6 bar sitting in my garage, but with the way the rules are for SCCA TT, Sport category only allows anything sold by Tire Rack (which is the Eibach 25mm and Whiteline 22mm) and Progress. I think the RV6 is superior to any of those - they are at least open with the rates of the bar - and should be less of a maintenance/noise headache than the Karcepts, but it has to be legal first. I wrote in to see if it can be specifically allowed, but TBD on that at the moment. Failing that, I would probably go with the Eibach from the available options.
I didn't really play with rear pressures much yet, I spent most of the day last time just trying to figure out where all the tires roll over evenly, but I would probably take a few pounds out of the rear next time.
