Yup maybe a different company would make it for cheaper in the future ... I’m ocd with shit like this I can’t drive with a light on so I’m most likely going to get it.So it's just a light? And it costs nearly $500 to turn it off?
If you buy this you will be getting it with no lube. It just four resistors. That first harness isolates the four dampner wires coming out the vdcs then that little black box has four resistors that have the same resistance as the dampner. I guarantee if you open that black box up it will be four resistors. Realisticly this is ay most 100 dollars. Diy you could do this for under 10 dollars.Yup maybe a different company would make it for cheaper in the future ... I’m ocd with shit like this I can’t drive with a light on so I’m most likely going to get it.
You gotta pay for that HKS name thoughIf you buy this you will be getting it with no lube. It just four resistors. That first harness isolates the four dampner wires coming out the vdcs then that little black box has four resistors that have the same resistance as the dampner. I guarantee if you open that black box up it will be four resistors. Realisticly this is ay most 100 dollars. Diy you could do this for under 10 dollars.
It also disables the ADS control unit which can interfere with the rotational inertia of the chassis (yaw and pitch).So it's just a light? And it costs nearly $500 to turn it off?
The AHA receives several inputs from the ADS control unit. An ADS error completely turns off the unit (and a portion of AHA) vs. simply not receiving damping inputs courtesy of the cancellation units. With other platforms, users would notice an increase in understeer due to the absence (or significant reduction) of torque vectoring. It's largely considered a safety parameter.How does the ADS do that?
I was just wondering if it could be done with a soldering iron. I know this post is long past due is there a video showing how to build them? I also found some for 237 via TeinIf you buy this you will be getting it with no lube. It just four resistors. That first harness isolates the four dampner wires coming out the vdcs then that little black box has four resistors that have the same resistance as the dampner. I guarantee if you open that black box up it will be four resistors. Realisticly this is ay most 100 dollars. Diy you could do this for under 10 dollars.
