gnarlynick
- Aug 25, 2020
- 8
- 0
- calgary, alberta
- 2020 honda civic
I'm in the process of installing a subwoofer right now; everything is wired and SHOULD be good to go, but the signal coming from the back two shelf mounted speakers is waaayyyy to weak. I'm using this LOC: https://www.visions.ca/catalogue/ca...MIobH3zYu36wIVExLnCh2TRw_REAQYAyABEgJTPPD_BwE (new, tested and working) to send signals to this amp (tested and working): https://www.amazon.ca/Pioneer-Gm-3300T-2-Channel-300-Watt-Amplifier/dp/B0088XZXYE to a used sub that has also been tested and works.
I cut all four (2+ and 2-) wires that go to each speaker, and spliced in an extension wire to take all + and - (two of each, left and right channels) to the LOC. I tested the power coming out of the speaker wire (Pre LOC) and the power BARELY moved the needle on my voltmeter. There's just not enough in there for the LOC to process and send to the amp. Is this due to a crossover network or something? Anyone have any ideas? Should I just take the signal from the front door speakers instead? Thanks for any help you can offer!
