Stripped screw on splash guard HELP
Andre
Andre
Dallas
2019 Civic Type R
while i was doing the oil change the screw that holds in the metal shield stripped. Any recommendation on how to take it out fix it although it’s stripped.
Honda Civic 10th gen Stripped screw on splash guard HELP BE57912C-129E-463F-9AFA-38910EBB43D4
Honda Civic 10th gen Stripped screw on splash guard HELP 127E47E4-A23A-44B0-A201-5083DBDA3792
fenix-silver
Central PA
2019 Si
Vise grips head should do it.
Donuyen18
Garden grove
Honda s2000
Take a phillips head screwdriver and ise a hammer to give it a few tapes so that it indents the screw farther in. You should be able to screw it out easily after that
Thusee
Thusee
Markham
2018 civic si sedan
i replaced all of my clips and twist screws with 10mm m6x1.0 bolts. So just use a 10mm socket everytime now and no issues lol...twist screws and that phillips one kept pissing me off.
but yea use a vice grip...you can put in a m6x1.0 bolt with a bigger washer to cover the hole. works the same as those phillips bolts.
chainsaw
Sacramento
2018 Civic sport hatchback 6mt
a left handed drill bit should get that out. the auto parts store usually sells kits with a few different size bits for not too much $$. good luck.
Andre
Andre
Andre
Dallas
2019 Civic Type R
hey everyone just wanted to say i got it out. those screws really suck lmao
TimberWolf
Bowser, BC, Canada
'17 Civic Hatchback Sport Touring 6MT
How much torque are you using to tighten them? Shouldn't need more than about 7-10 lb-ft. Also, you should use the correct tool. Don't use Phillips head screwdrivers on the car, use JIS drivers.
fjrman
Tennessee
2016 Civic 4 door LX with CVT
You might make a straight groove across the top of the screw with a hacksaw. You could then use a large straight blade screwdriver to install/remove the screw.
latole
Vaudreuil,Quebec ,Canada
Forany screw, you must use the bigger screwdriver head screw can hold.
I'm sure you use a too small screwdriver.
fjrman
Tennessee
A phillips screwdriver doesn't work very well with these screws. I noticed this the first time I changed the oil. For a car built in the USA I don't know why they used a non-Phillips screw. I doubt they imported the removable cover from Japan.
latole
Funny, no issue on our two family Civic with more than 15 oil changes by myself.
Something you may do wrong.
fjrman
Tennessee
Doing nothing wrong. A phillips will work adequately but it's not a match for the screw.
