Myx
- Mar 6, 2016
- 79
- 2,166
- 2,042
- Delaware
- 2018 Honda Civic EX (Hatchback/CVT)
- Vehicle Showcase
I've read that the replacing the stock downpipe and frontpipe will allow our Civics to gain horsepower. The downpipe (cat) and front pipes that replace our stock ones are larger in diameter (2.5" to 3") than the stock one (2").
So, looking at the stock downpipe and front pipe, I notice a few things. The stock downpipe (cat) has a large opening and goes down to a smaller opening. Replacing the cat with an aftermarket one I can understand would help you gain horsepower. But why would a larger front pipe gain your horsepower?
I ask because the front pipe is the same diameter as the rest of the exhaust going back to the mufflers. I provided a pic of both the stock downpipe (cat) and front pipe. Look closely at the front pipe. Where is there a restriction? If the diameter of the front pipe is a restriction, so would the rest of the exhaust going back to the muffler as well.
1) So how it is that the front pipe is a 'restriction' and replacing it with a larger diameter front pipe yield horsepower gains?
2) How does going with a larger downpipe and frontpipe gain you horsepower when the rest of the exhaust is a smaller size? Why not go with the same size downpipe and front pipe as the stock exhaust? Or at least the front pipe since the innards of the stock cat can be a restriction?
A lot of folks here are a lot smarter than I so I am just asking a few questions. Some of this doesn't make sense though.
Edit:
I just looked at dyno runs of AFE aftermarket downpipe, front pipe and exhaust tested individually and they all added horsepower and torque. Below are the links.
AFE exhaust: 7whp (This was installed first with stock downpipe and frontpipe). HERE
AFE downpipe: 5whp (On lowend. Topend, they were experiencing hp loss due to hot intake temps/ignition timing being pulled. HERE
AFE frontpipe (Or Rear Downpipe they called it): 10whp. HERE
Blog Details on full exhaust setup: HERE
Edit:
