Steering wheel vibrating, driving on the highway
THATREDFK8
Dallas
2018 Honda Civic type r
Driving on the highway today, notice steering wheel vibrating, if anybody have this issue or I’m just tripping? Lmk!
jayy_swish
Jay
Are you running aftermarket wheels ? Is it under braking conditions or just when driving?
jayy_swish
Jay
Then it should be normal vibration or maybe your wheels might just need to be rebalanced, Honda should do it for free if under warranty.. or go to a tire shop and it should be fairly inexpensive
THATREDFK8
THATREDFK8
Dallas
Sounds good, thanks for the help
Jimmou
Jim
Fresno, CA
2019 Civic SI Sedan
Vibration, especially Those get in the steering wheel, that become more apparent at high speeds is usually an indicator of unbalanced wheels.
trucke
Art
Hendersonville, North Carolina
2019 CTR; 2022 Civic Si; 1987 Corolla FX16 GT-S
You may have thrown a wheel weight. A visual check should confirm. Then its just a wheel balance.
J o n
Pittsburgh
'15 Z/28, '22 Ridgeline , '22 CR-V Hybrid
Wheels may balance on a normal spin balance machine, within spec. However there's varying harmonics at different speeds that will create vibrations, noise, steering wheel shake. Roadforce balancing is the only way to measure and determine the wheel and tire impacting these issues. Big wheels and low profile tires are worth extra money for roadforce balancing (~$100 for 4, depending on sidewall profile). Some brand new tires are found to be out of spec due to their roadforce rating, same can be said for wheels.
Gansan
Glen
San Diego, CA
1999 NSX, 2018 Civic Type R
When my steering wheel was vibrating slightly on the highway, it turned out my wheel was bent.
J o n
Pittsburgh
Bingo, roadforce balancing will detect this. Spin balance won't
m_kluch
Maryan
Michigan
2018 Civic Type-R
Start with the cheapest and most probable thing first and rebalance the two front wheels.
Rottboy
Western Canada
'20 BB CType R; ''17 Alfa Romeo 4C Coupe; 15 Honda Fit LX Manual; '14 MB G550;
My guess, 2018 MY having mileage accumulated, it's a thrown wheel weight. Take M_Kluch advise and go the cheapest route. Balance the fronts!
