Alphaskoom
- David
- Feb 4, 2020
- 55
- 511
- 219
- DFW, Texas
- 2020 Civic Coupe Sport
- Vehicle Showcase
i just removed the steering wheel swapping out the trim pieces, and putting it back together, reconnected the airbag lines and ground plug for the horn, now when i go to turn the car, there's a consistent clicking about 3-4 times once i get outside of 45 degree wheel turn till wheel lock with each direction. The noise is not coming from the engine bay but around the steering wheel itself. It sortra reminds me of that noise that is made when people put cards or zipties so they rub against their bicycle wheel. I have all 4 screws holding the trim in place, the ground screw from the back cover connected and behind the little clip on the left, and the main plug on the right behind the clip. I'm likely going to remove the airbag again and see if i can find anything loose. I hope i didn't damage anything trying to get that bolt out, I did the best i could holding the wheel with my knees while i took a breaker bar to the bolt to remove it. or did i just royally screw myself and might have to buy a new steering column?
I'm kinda tempted to reconnect the battery with the airbag off and see what happens when i rotate the wheel but i get the feeling this will anger the airbag light gods and id rather not leave that code in the car if i can help it. Any ideas?
