Amidnightproject
My lc2i is just the standard settings right now while the sub breaks in.What are your settings for the lc2i and amp? That is, how did you setup the threshold, accubass, and amp gain? I installed a similar setup this past weekend but I haven't found the best settings yet. Bass roll off starts at vol 20 for my ears, but maybe someone with a RTA can confirm?
I know it will all depend on personal preference but I'd like to hear what others have done.
But the way I setup the amp is like this.
I set my bass and treble on the head unit the way I wanted it. I also set the music volume to 24 while I was making adjustments. I noticed I don't play music louder then that. I set the bass EQ level up on the amp until I was satisfied.
Then I set the gain level on the amp while watching it with a volt meter playing some songs I knew hit rather low since I didn't take the time to acquire a tone reference track. Using some math you can get a good idea of what your gain max should be without causing speaker damage.
Take your rms output and multiply that by your speaker impedance. Then take the square root of that number. Since I have two 4ohm coils wired in series, it has 2 ohms of impedance. Speakers all have different setups though. Your specs or better yet a volt meter will verify what your impedance is.
So for me it was 500x2=1000. Then sqrt of 1000 is 31 and change.
If the max rms of your sub is lower then your amp, then use that number. In my case the rms of my sub exceeds my amp by double.
So i turned up the gain until the output voltage AC was about 27-28v during the loud bass drops leaving some head room for error.
My HP filter I dialed down a little bit to clean up the sound.
I found that setting up the amp while the music was at the highest level I ever really listen to (24) I don't have much bass roll off at higher volumes. There is some but Im going to let the sub play in for a couple weeks before I make any changes to it.
Hopefully that helps a bit. Sorry for the delayed response!
