stages?
MrTureelok
Ribardo
the Dessert
2019 Civic Si
what are the stages if anyone knows? like what would fall under stage 1 and so on and so on. For the Si of course :)
jimmyreal
Jimmy
NC Triangle
'20 Civic Si sedan
Stage 1 typically refers to bolt-on mods that don’t require engine work to, well, work.
Stage 2 typically is talking things that require engine work. A bigger turbo, for instance, or a tune for E85 that requires a flex fuel kit.
Stage 3 is typically race- or track-centric mods that make the car less, or even not, street drivable.
MrTureelok
MrTureelok
Ribardo
the Dessert
2019 Civic Si
  • #3
im full bolt ons with tune of course and getting a clutch upgrade this monday from OEM , after that im either going to go flex or bigger turbo just dont know when because of the clutch only holds up to 364 wtq
dark_knight097
Daniel
Georgia
2017 Civic Si
Make sure to break the clutch in real good first. 500 miles minimum.
That clutch(ACT organic?) should be good to hold the torque from a bigger turbo and flex. As with the current turbo options and flex, torque numbers generally range anywhere from 290-305(pump gas) and 310-335(flex fuel). I have seen a few higher but nothing exceeding what that clutch is rated for unless you're using meth injection.
MrTureelok
MrTureelok
Ribardo
the Dessert
2019 Civic Si
  • #5
currently breaking my clutch in, just got it yesterday. Sucks taking it slow especially when I was dealing with the OEM one slipping every gear for about a month haha. Yes ACT organic. currently thinking of how this clutch would hold up with E85? DO you know anyone whos done it and what their numbers are looking like?
