jaydubz79
But can you buy Hondacare after delivery?Or buy Honda care for 1k and drive it for 9 year like you stole it.
Does sport mode affect exhaust sound I can't find that anywhere nor have I noticed a difference?After about 15,000 miles I noticed that the car sounds better in "Sport" mode. Before that I didn't hear much difference.
Yes.But can you buy Hondacare after delivery?
Honda Care can be purchased anytime until 3 years or 36,000 miles. After 6,000 miles, the plan numbers change and the prices increase by a small amount.6 months or 6k miles..
I does not have any kind of active sound change. I believe what he's referring to is the slight change in tone one can hear under the more aggressive mode. Small things can change tone for good or bad; many Mazda3 owners found that swapping the rear motor mount changed exhaust tone for the better.Does sport mode affect exhaust sound I can't find that anywhere nor have I noticed a difference?
Nope. Not one bit. I would much rather have all the torque I have now. (my 2018 si vs previous 2014 si)True that man, I hear ya... I could the difference between both modes, being my first Si and with no Vtec. Which bring me to ask, do any of you with previous Si models miss the vtec?
Up to about 15,000 miles, I could hear no difference in the sound between regular mode and Sport mode. After 15,000 miles I began to hear a difference. Now at 25,000 miles, Sport mode sounds a little deeper and throatier. I haven't found in any documentation why this should be.Does sport mode affect exhaust sound I can't find that anywhere nor have I noticed a difference?
When people say "Sport Mode does nothing", it is based upon the expectation that Sport Mode would provide teeth rattling rock hard suspension on a smooth road, like a Ford ST. Honda engineers were smarter than that.I can barely tell the difference between sport mode and normal as far as stiffness is concerned. I can't imagine the dampening is must more aggressive... So its unlikely that being in sport mode 100% of the time has any affect on shock lifespan... That said... Its a new platform so only time can tell for sure.
Sport mode has no effect on the spring rate progression or total range of motion - those are determined by the design of the coil springs and geometry of the suspension.When people say "Sport Mode does nothing", it is based upon the expectation that Sport Mode would provide teeth rattling rock hard suspension on a smooth road, like a Ford ST. Honda engineers were smarter than that.
When Sport Mode is activated, the wheel's total range of motion is more constrained. In Sport Mode, suspension dampening increases as wheel moves further away from the static ride height position. It is important to note that Sport mode does not increase stiffness across the entire range of wheel travel. If you are on a smooth road, it will be difficult to feel any noticeable change, because it's not designed to do that.
Sport Mode is noticeable if you hit a large bump. Also, the car will squat less under hard acceleration.
I see your argument but I am failing to see where I said "Sport Mode does nothing". I said "I barely feel the difference, not that there is no difference at all. My main point was that there is not a drastic difference in dampening and therefore likelihood of using this mode significantly affecting lifespan of the shock.When people say "Sport Mode does nothing", it is based upon the expectation that Sport Mode would provide teeth rattling rock hard suspension on a smooth road, like a Ford ST. Honda engineers were smarter than that.
Impressive number of milesUp to about 15,000 miles, I could hear no difference in the sound between regular mode and Sport mode. After 15,000 miles I began to hear a difference. Now at 25,000 miles, Sport mode sounds a little deeper and throatier. I haven't found in any documentation why this should be.
I wasn’t quoting you.I see your argument but I am failing to see where I said "Sport Mode does nothing". I said "I barely feel the difference, not that there is no difference at all. My main point was that there is not a drastic difference in dampening and therefore likelihood of using this mode significantly affecting lifespan of the shock.
The throttle position is computer controlled. The throttle is actually more responsive to pedal input mid-way through travel in normal mode. This is good for everyday driving, passing on the freeway, darting through traffic etc.Steering is too light with SM off . I like the steering feel with it on .
I can barely tell a difference with the suspension unless I'm really pushing into turns
Can't tell a difference in throttle response at all
Never hear a change in sound but this car doesn't make sound anyway haha
