Pouyan Pasyar
- Civicfk7
- Apr 17, 2018
- 29
- 9
- Bay Area
- Honda Civic hatchback sport
Here is the video!
Probably since the battery has been disconnected all the systems have to initialize and run checks, then they will go off.IT'S ALIVE!
But also - is that a normal amount of orange lights on the dash?
They will go off after couple miles! The mechanic is going to test drive today and then I’ll pick it up!IT'S ALIVE!
Did you have to change the ECU since the engine is different?They will go off after couple miles! The mechanic is going to test drive today and then I’ll pick it up!
Nothing needed! Simple swapDid you have to change the ECU since the engine is different?
@Pouyan Pasyar - Pretty sure the above question is relevant. If memory serves, the Si engine has slightly lower compression (10.3 vs 10.6), and the turbo has less blades (9 vs 11). I would think if you get a custom tune made, you'll be safe. Hell, even without.... you might be ok (provided you can avoid abusing it).Looking at the phones - did they just use the Si engine block and swapped the turbo over from the blown engine?
I’m getting it tuned! The AFRs were ok as I checked today. Knock didn’t go above .53 fortunately.@Pouyan Pasyar - Pretty sure the above question is relevant. If memory serves, the Si engine has slightly lower compression (10.3 vs 10.6), and the turbo has less blades (9 vs 11). I would think if you get a custom tune made, you'll be safe. Hell, even without.... you might be ok (provided you can avoid abusing it).
Yes sirLooking at the phones - did they just use the Si engine block and swapped the turbo over from the blown engine?
Which ECU is @Pouyan Pasyar using?Which MAF sensor are you using... non-Si?
well the stock maf stock ecu is different from the SI to the Sport, so are you using the sport or the SI stuff.I’m using stock maf stock ecu stock tune! Looking forward to get a tune.
He probably means Sport. As Micah implied, mismatching the two would not get him anywhere.well the stock maf stock ecu is different from the SI to the Sport, so are you using the sport or the SI stuff.
