Spoon Sports Rigid Collar Kit
Weesawn
San Jose,CA
2017 Civic Si
After doing some research on the Rigid Collars for the CTR and saw the positive reviews on them I was curious if they will fit on to the Si as well. Anyone have any input on this?
Delta MoSports
Toronto, ON
www.deltamotorsportsco.com
2017 Honda Civic Si, 2018 Honda Civic Sport HB, 2017 Honda Civic Coupe, 2015 Honda Civic Si, 2005 Acura TSX, 1999 Lexus LS400
Hey Weesawn!
The spoon rigid collars do in fact fit the Si. We run them on our track car and have been great in the road feel and helps align the subframe a lot better!
Weesawn
San Jose,CA
2017 Civic Si
  • #3
Hey Weesawn!
Awesome, thanks a lot for the info!
skottharrison
Skott
South Florida
2020 Civic SI Sedan, 2021 Subaru Crosstrek
Howdy,
Are the Spoon rigid collars re-useable, as in, if you drop the subframe again, do the collars retain their benefit? Thanks!
Unity Performance
Humza
unity-performance.com
2017 Si Sedan - Blue (Humza) | 2018 Si Sedan - Red (Thusee) | 2018 Type R - Black (Nima)
T
Howdy,
If you're just removing and then re-installing the subframe, then likely yes, but if trying to swap out to a different car then likely no.
Did some more digging before posting, and here's an article on it that matched my thought:
"Once a Spoon Rigid Collar Bushing set is deformed on a specific chassis and subframe we feel this "mates" these items all together and that attempts to move used bushings from one car to another would be an unsuccessful job."
https://www.heeltoeauto.com/spoon-rigid-collar-bushing-reuse-are-they-one-time-use.html
There is a reason why the Front and Rear kit has been sitting on my shelf for 8 months now...to keep Blue or to get the older brother is the question 🤔
CanadiaegeanBlue
Humza
@Unity Performance have you installed the rigid collars yet, or are you planning to at any point? I am contemplating putting these in the front while I do my clutch at same time. Cheers.
Not yet sir, will be Spring item most likely. Way too many other projects on the fly at the moment
Our local friend, @Delta Motorsports has them on his FC1 Si
