sounds like i ran over sheet metal
godsmacksully
Emily
Galena, Illinois
Honda Civic Type R, Ford Focus, Honda CBR500
yeaterday I noticed a sound when I was coming to a stop that sounded like I ran over a piece of sheet metal. Only heard it once. Then the next day I heard it again. I actually got out to see if I ran something over. It sounded like it was coming from the front. Well then today I closed the hatch and it sounded like the same kind of rattle but coming from the back of the car.
godsmacksully
godsmacksully
Emily
Galena, Illinois
It happened again as I was pulling into my garage tonight. Slightly turning the wheel and breaking to pull up a hill. Sounded like a grinding clip or spring or something like that
Swank
Calgary
2018 Civic Si Coupe Black
Could also be a brake pad squealer if your pads are due for replacing, front ones always go first.
fiend busa
2018 Civic Type R
I have the exact same issue! It's hard to reproduce though as it occurs randomly
NoKz
Speed Limit Tester
'18 Si Coupe (Sold 12/2021)
Tap your brake dust shields. Sometimes rocks and gravel get caught in there and rub against the rotor and shield. Easy fix.
R4T3DCTR
Alex
Barrie Ontario
2019 Civic Type R
I have this exact same issue, currently 10,000km on my CTR. The odd stop at a stop sign or slowing down a random metal panging happens. I have contacted Honda about the issue and they have never heard of such thing, and I cannot seem to reproduce the noise on command. I took the skid plate off underneath the car noticed a lot of debris and rock. However there does not seem to be any signs of wear on the oil pan or surrounding components. So, my guess would be is its probably rocks rolling around and striking metal, but I agree the first time I heard the noise I thought the worst.
TheSnakeJake
Jake
Cincinnati
CTR
this is definitely a rock stuck behind the brake shield. i have one right now also...
CW20038TypeR
Franklin
CW type r 2018
I had this before too
sounds like a spring unwounded Releasing its energy and makes like a twaaaang sound
BOOYA
Kyle
Canton, GA
2019 Type R
I searched the forum for this very issue. I have a new 2019 CTR (December 2019). From the beginning, I have noticed a very occasional rotational "twang" sound when nearing a stop. Definitely from the front end and likely from the front right. Once it does it, it won't do it again for a while, so it's extremely hard to drill down exactly what it is. I put it up on ramps last week for the first time and couldn't see anything abnormal, even with skid plate removed. If I "flick" the brake shield (pull on it slightly and release it), it sounds exactly like the sound heard from in the car. I'm guessing this has something to do with a caliper sticking or grabbing the shield?
Has anyone from this thread found a solution? Thanks!
alvav
Leonidas
Naxos, Greece
2018 Civic Type R, 2019 Acura NSX
Definitely a rock in brake shield. Makes all sorts of weird sounds that you would swear could not possibly be caused by this (screeching, twangs, spring pops, etc) but, when the rock was removed, all sounds stopped.
BOOYA
Kyle
Canton, GA
2019 Type R
Do you have to remove the wheel to get that out? I pulled on the shield all the way around it and am just waiting to hear it again. That was only a few days ago.
omar0123
Omar
Puerto Rico
2019 type r
Happened to be like twice definitely rocks in the breaks clear it up and no more crazy break sounds these sticky tires pickup rocks and some they find there way in between the brake shield and disc .
