Something finally broke
Tanuktun
Tomball TX
2019 Civic Ex Hatchback
Just had my 3rd oil change at 15k, go to pick it up and the guys tell me I need to go to the dealer because she's leaking coolant.
:eek::eek::eek:
I'm losing my mind as soon as he tells me, I'm thinking oil dilution, A/C, pick a gasket, hole in the radiator.
Came home, flashed to stock, drove til the lights went away, went to the dealership and waited 15 minutes for them to inspect it, they walk me to the back and tell me it is NOT a coolant leak, the carrier bearing on the passenger axle failed and the grease in the bearing was liquefying and slinging.
I have no idea how that failed 😅😇😇
The put me in an ELite Pilot, which by the way is very f'n nice, makes me want a passport. Said it should be fixed later today 🤞
JT Si
JT
Willamette Valley
2018 MSM Civic Si
The bearing for the intermediate shaft on the passenger side is exposed to only small amounts of torque, since it's mostly just a pass-through to the axle and hub.
Tanuktun
Tanuktun
Tomball TX
  • #3
That worries me more then since It's failing at 15k
JT Si
JT
Willamette Valley
2018 MSM Civic Si
A defective part is a defective part. I doubt having a tune caused that bearing to fail if it otherwise was not defective due to the low amount of torque it receives.
Tanuktun
Tanuktun
Tomball TX
  • #5
Guess i'll just be happy i dont have to pay anything and its being fixed lol
Rustlinjimmies
Meh
Corona CA
2019 Honda Civic Si
it happens I've seen those carrier bearings fail at work on the fords we work on and no tunes on these cars just a whatever design. Not the end of the world and quite honestly even out of warranty not the hardest job to do. Just a lot easier to do on a lift
Mikeybc
Northern Ontario
2017 Civic Coupe EX-T, 2015 Nissan Murano
It's pretty scary to me that the guys got a coolant leak confused with grease.....no matter how liquified the grease became. I'd be avoiding that shop in the future.
JT Si
JT
Willamette Valley
2018 MSM Civic Si
I wonder if they are going to replace just the bearing and seals or the entire intermediate shaft?
For some reason the intermediate shaft assembly costs almost twice as much as an axle.
Tanuktun
Tanuktun
Tomball TX
  • #9
It's gonna to know that its nothing I did and the showed me what the problem was, i just never heard of it.
And idk about other dealers but they did this whole text message video inspection thing, that they are apparently going to make the norm
Tanuktun
Tanuktun
Tomball TX
  • #10
part of what i was thinking because when you think coolant, you think green. i didn't know and im sure those guys didn't know, hondas is blue apparently. but they showed me where it was collecting at, at the dealership and i could understand the confusion, it was dirty green collection of fluid.
Rustlinjimmies
Meh
Corona CA
2019 Honda Civic Si
my guess is just the bearing if the shaft isn't damaged and leaking they wont bother touching the half shaft
Mikeybc
Northern Ontario
ahhh I see, First thing I do on a suspected coolant leak is taste it......unmistakeable.
DRUSA
Dan
2018 Civic Type R #9141
Checked the forums as I have seen this a few times as well on other models and just kind of disregarded it. There is no grease in the bearing or seal for it to fail. Other techs are thinking is an internal leak of the passenger side inner cv joint, cv grease leaking past the cup into the splines (skeptical of this imho, its a sealed cup unit) or what i think may be more accurate is that during assembly a small amount of cv/moly grease is applied to the splines of the intermediate shaft, this could just be excessive grease leaking out and nothing more. Someone at the plant getting too wild with the lube.
DRUSA
Dan
