Goseki
- Sep 3, 2018
- 14
- 99
- 64
- Florida
- 2018 Civic Touring
So I'm finally getting around to enjoying my 2018 Civic Touring, and there's a few quirks I had questions I was hoping fellow CivicX peeps who have had their cars for longer can answer for me.
1) What is this? I found it in my trunk rolling around the other day. Also is there a storage spot for this? I assume it must've fallen out somewhere.
2) The chrome door trim that goes along the bottom of the doors, is it just attached on with tape? I was planning on getting these from the dealership, but if the install is simply clean the door with some alcohol and stick on the tape, I think I could do that myself.
3) When I go to fill up the gas tank, the nozzle doesn't really fit that well into the cap-less hole, there's some "loose-ness" and the whole receptacle just feels more plastic and less attached to the car than any other car I've had before. Is that normal? I've also noticed that at different gas stations, when attempting to fill the tank, it will often stop short multiple times and I have to really push the nozzle all the way in for it to actually fill all the way until full.
4) In other cars I've driven that had bluetooth, if I call someone and step into the car, the audio is instantly switched over once the bluetooth connects. This car is the only one I've been in where if I'm already in a call and the phone connects to the car afterwards, the audio stays on private, is there a way to change this?
5) Is there a way to disable the pop up notifications from the infotainment when the car first starts? I'd also like to disable having to "select audio source" every time I switch to music as well if that's possible?
6) Are the trunk shopping bag hooks worth it?
My gift: I've found that lipstick is an excellent filler for small-med abrasions in the paint. Here's a picture of the before/after. I used lipstick on the bottom spot and no lipstick on the top and the bottom turned out 100x better.
I've attached 2 pictures. See if you can find the lipstick repair!
Original Damage:
After the fix
Original Damage:
After the fix
