Sold: California sold
jakdotdot
Cali
2018 SI
Used set of Garage Line Spacers 20MM 5x114. Used for less than 6 months (Got new wheels)
$140 OBO
Available for pickup in Sunnyvale 94087.
Honda Civic 10th gen sold image0 (21)
jconnway
James
New York
2019 Sport Hatch 2017 Sport Hatch
Do you need to roll fenders with these on a modest drop
cekIV
Chuck
IL
2019 Honda Civic Si Sedan
Will you ship?
jakdotdot
jakdotdot
Cali
2018 SI
With a stock-ish wheel size, you should be fine. Worse case, you might want to do the fender tab mod, but that might only be needed on the 2016-2018 cars. At some point Honda removed the tab so you no longer need to do the mod.
Will you ship?
If you pay for it + pp fee's.
Syntek
Los Angeles, CA
2019 PWP Civic Si Sedan
The 2019's don't have that tab anymore?
I only ask since i am rubbing with the oem wheels on whiteline springs (minimal drop) and these spacers.
jakdotdot
jakdotdot
Cali
2018 SI
I heard that they removed the front tab at some point, but I am not 100% when. Feel free to check your own car.
Also, I wouldn't call 1.4 inches a minimal drop.
Syntek
Los Angeles, CA
I'll check my car and see if it's there.
Whiteline springs drops the car 20mm all around, which is less than an inch drop
jakdotdot
jakdotdot
Cali
2018 SI
Ah Map's site has a 35MM drop listed for some reason for the WL springs.
You can try fender tab mod (if you have a fender tab) or adjusting the alignment via camber arms, etc. It all depends where you are rubbing.
It's going to very to some degree depending on your setup, tire make and size, alignment, drop of springs etc. Also, what type of driving you are doing. A setup may not rub much or all on the street may rub on the track.
*I cannot and will not personally guaranty anyone's setup won't rub with spacers.
Syntek
Los Angeles, CA
Just for reference, those looking for these spacers on OEM wheels with the factory-sized tires and factory springs, there is no rub from my experience. Took the car to streets of willow on the spacers with stock springs and there was absolutely no rub including hard bumps.
On the new springs (a 20mm drop) there is minor rubbing on hard bumps with the OEM wheels + tires. I also am running adjustable lower ball joints and have my camber set to around -1.7 loaded. YMMV for other Si users.
In any case, these are a great price for these spacers.
GLWS OP :thumbsup:
