- Feb 15, 2017
- 108
- 4,710
- 4,873
- USA
- 2019 Accord Sport 2.0T, 2017 Si Sedan (Sold), 2017 Sport Hatchback (Sold)
- Vehicle Showcase
For sale, Ground Control Coilover Kit with Modified Dampers for the 2017+ Si.
The kit includes the Ground Control Coilover Conversion Kit (MSRP $799.99) and a set of OEM front dampers (MSRP $1,187.00, lol @ OEM Honda prices) that have had the spring perches carefully trimmed off, so that maximum negative camber can be achieved. This setup is easily good for 3 or more degrees of negative camber.
Spring Rates (recommend by Ground Control): 425 lbs/in (front) / 350 lbs/in (rear)
Other perks:
The price for all of the above: $799.99
Please PM if interested, thanks.
Other perks:
- Because this system is built around the factory dampers, you maintain the electronic firmness control
- No "ADS" error
- Full adjustability of ride height
- Able to be corner balanced
- Offers go-cart like handling, turns your Si into a precision weapon!
- All of the hard work has already been done! (several hours of blood, sweat, and tears!)
- Ground Control advertises a maximum drop of 1.75", but if you drop it that low you are going to have issues with the dampers bottoming out, due to reduced travel because of the camber plates
- NVH is often present. It's not unusual to sacrifice noise and comfort in the name of performance, but noise is to be expected with this setup.
- The ride is somewhat stiff for the street, another compromise in the name of performance.
