So about rev hang
TTRPGGeek
Indianapolis
2016 Accord LX
I have no intention of boosting power - prefer longevity. But, was wondering if aftermarket rev hang only fixes exist. Or, is that just part of a Hondata ecu flash? Can you flash and just eliminate hang without any other tampering?
ne0guri
Mars
2017 White Orchid Pearl Civic Si Sedan
I was wondering as well! Cold Air Intake? Aftermarket Intercooler? I don't know what I'm saying but maybe?
Bu66a
Maurice
2017 Honda Civic Ex-T Sedan
I'm very interested in finding out about this too
TTRPGGeek
Indianapolis
2016 Accord LX
As I understand it (And, for the record, I don't change my own oil so I don't understand much :) ) the rev hang is entirely computer controlled, so the ECU (the engine's computer brain) being reprogrammed should do it. Reprogramming the ECU is all a Hondata flash is too, as I under stand. So really I'm just wondering if there's an ultra gentle and not full Hondata tune priced ECU update just to kill rev hang.
zx2down
Philly
2014 Altima 2.5 S
They can easily make a flash that is JUST a rev hang fix. I know with Ford ECU once you hack it you can see ALL the stock settings. I imagine the Honda ECU is similar. So they can make a tune that is 100% identical to stock + a rev hang fix.
neteng101
NJ
2017 Honda Civic Hatchback Sport Touring
I would suggest going with a mid-tune - you can always reflash to stock if you're worried before taking it in to a dealer for service. The car won't break! Don't be afraid - and the tune gives you the most gains so its a win-win, leaving all else stock.
Bu66a
Maurice
Will tuning hurt the longevity of the engine? I've never flashed before
JDM_DOHC_SiR
Uncle Dave
Chula Vista/ Eastlake
neteng101
NJ
The longevity of the engine will be determined by how you actually treat the engine - flogging a stock engine will cause more harm than treating a flashed engine well... that doesn't mean you can't let it rip every once in a while, but if you're constantly in lower gears and keeping the engine at higher RPMs all the time, or doing laps on a track, etc, then of course the longevity of your engine is going to be shortened - stock or flashed. If you drive it normally and have some fun, your engine isn't going to know the difference.
pukemon
TX
2014 DBP Civic SI
Quite sure rev hang can be tuned out. Might want to ask vit what options he might have for tuning rev hang out and possibly keeping the stock tune to a very very mild tune to get better mpg. If hondata is still the same price that's what $700 to get rid of rev hang.
Bu66a
Maurice
zroger73
United States
I thought the reason for rev hang was because the throttle doesn't close immediately after you step on the clutch due to emissions purposes? So what would a crank shaft pulley do....
Absolutely correct. You could have a crankshaft made out of toilet paper tube and a flywheel made out of paper plate and you'll still have rev-hang as long as the ECU prevents the throttle from snapping closed once you let off the accelerator in order to control emissions, which is the cause of the type of rev-hang in the context of the Civic.
Fanoflive
Jeremiah
Belvidere IL
2017 Honda Civic Coupe EXT 6MT
I havent seen anything that says that the Rev-hang has been resolved with either Hondata or KTuner? Am I missing something here? This is one of the reasons I have been holding back on purchasing either tuner. I want the Rev-hang gone!!!!
zroger73
United States
I haven't heard anything, either. Being an emissions-related function, the code that controls this may be buried deep within the ECU's programming or may be difficult to reverse engineer. It's also possible that it is hard-coded and not something that can be changed via firmware. If I were a tuner, I'm not sure I'd want a part in altering code that affects the position of the throttle blade as this could present a huge liability issue if some went wrong causing the throttle blade to open unexpectedly.
